Results 1 to 7 of 7
    hi,
    i am getting a humming sound when running at "exactly 40kph only." nothing more nothing less. it is also NOT dependent on engine rev and gear.
    if its not wheel bearing, what could be it?
    tire noise? Resonance issue?
    May 2007
    It you suspect its the tire, check for cupping also known as "Feather Wheel". If it is, two main causes: toe adjustment and weak shocks. Once the tire becomes cupped it wears like that and stays noisy. You can correct the root cause, but not the cupped on the tire.
    shocks - newly replaced a year ago. been using it daily driven, home/office only no tracking.
    cupped tires as in vulcanized?
    Jul 2003
    wheel bearing noise will be audible from any speed, and it will change pitch from low to high. it will be more of a grinding noise.
    cupped or feathered tires is caused by wheel alignment problems in general.
    Tire service centers with wheel alignment systems can help you on this.
    Depending on your vehicle type, when shocks are replaced, it may need to be wheel aligned at the same time.
    Nov 2003
    probably a resonance issue. nothing major imo.
is this still wheel bearing?
