Results 11 to 18 of 18
July 24th, 2013 10:01 AM #11
And afterwards, one realizes that spending to make sure the ABS worked well seemed viable after all.
On a related note, ABS saved my car's ass the other morning on EDSA. There was a sudden stop of fast moving traffic on the lane i was on (right before the Rockwell/Estrella corner) and i knew i could stop on time and more importantly, steer clear of the stopped car in front of me. The vehicle behind me locked his brakes and may have rear ended me had i not switched lanes.
July 26th, 2013 07:27 AM #12
hay naku bakit ganyan mga casa imbes na gamitan ng scan tool (monitor waveform) or better ay oscilloscope ay swaptronic ang ginagawa. kaya resulta trial and error pag minalas malas customer bibile customer ng pyesang hindi kailangan.
- May 2012
- 37
July 27th, 2013 11:03 PM #13
- May 2012
- 37
July 27th, 2013 11:07 PM #14
July 28th, 2013 08:37 PM #15
http://alldatapro.com/alldata/PRO~V3...2168/133531695
check continuity/resistance at point B, for left side or position 1 it will be orange connector resistance between terminal 1
blu/orn and terminal 2 brn/wht , for right hand or position 2 it will be oraynje connector between terminal 1 grn/blk and terminal 2 blu. check the sensor side. since the last touched area was the bearing, check the lower extremity of the wiring harness and the sensor first.
May 3rd, 2014 06:30 PM #16
My problem is the ABS light turn ON and OFF. Sometimes it's On, sometimes it just turns OFF while driving on pave or rough road.
Car is CRV 4x4 2004 model. Nothing has been replaced, even the brake pads are still of the original and mileage is near 120K kms.
What could possibly be wrong ?
May 5th, 2014 11:57 AM #17
IIRC new Honda's ay wala ng tone ring, ang gamit nito ay magnetic encoder na sa bearing. either na mali ang bearing or baligtad ang pagkabit. (may kulay ang side ng bearing na may magnetic encoder)
May 13th, 2014 10:02 PM #18
^Probably some dirt stuck in the speed sensor. Have it cleaned lang. Kahit brake cleaner. If the lights come back, then have it scanned. It will point you to what sensor is malfunctioning.
i had mine replaced, but at the manila end. the las pinas end was closed at that time, kasi....
costal expressway
