Results 1 to 12 of 12
    Maingay pa rin ang brakes ng L200 namin pinalinis ko na sandali lang and maingay nanaman siya. BTW, our pick up is 9 yrs old.
    Ano po gagawin? The noise sometimes sound like 2 metal plates scrapping against each other
    Oct 2004
    Could be your brake pads (upod na). Could also be your brake rotor (warped na) or it could be both. Disregarding the fact na madumi or may tiny "bato" naipit between ur pads and rotor since napalinis mo na kamo.
    Solution: Bili ka brake pads tapos pa-reface mo rotor(pa check mo though kung pede pa pa-reface pag d na no choice but to buy). Then break-in mo ng tama since maling break-in also causes squeeks and wear your new pads prematurely.
    bago ba barake pads mo? kasi meron talagang kahit bago maingayparang nasa material
    Apr 2005
    brake drum reface,
    check brake lining ,baka kailangan palitan o kaya pa bonding
    Nov 2003
    should be easy to check what is causing the problem... have all brake components looked at.
    Mar 2005
    I remember when this happened to my car....yung break pads nabili ko inferior , i think may tinga kasi that's why maiingay....I changed it to bendix tapos ok na...
    Dec 2003
    sometimes on new pads may noise, after a few hundred kms it will disappear. break-in kumbaga
    Mar 2004
    sirs... what if yung ingay naman sa brake eh yung matining...yung parang sa bike? everytime na mag prepreno kasi ako rinig na rinig mo yung ingay. ano kaya cause nun? how do i get rid of it?
    Jan 2003
    bring it to a reputable shop.
    kung pinalinis mo yan, dapat kita na nila kung pudpud na brakepads
    ganyan din sakin bago pa brake pads ko binili ko kasi yung mas mura yun pala japeyk lol or sabi nga inferior...............
    Jun 2005
    next time when you have ur pads replaced or cleaned, lagariin mo yun gitna to make a shallow grove. this way when dirt seeps in there will be a channel for the dirt to come out. para hindi mag cake yun dirt
    Mar 2005
    Same problem as mine. I had it checked, makapal pa naman daw yung pads. The mechanic said may groove na yung disc but para hindi biglang gastos, linis lang muna at kung meron pa din, next would be pa-reface. So I had it cleaned and the pads sandpapered. For 1 week completely tahimik pero medyo nagkakaroon na naman uli. Pag maingay na uli, pa-reface na ako.
Squeky brakes despite palinis
