Results 1 to 12 of 12
    Yesterday, I finished the 30k KM PMS for my 2010 Forester 2.0 XS. However, during the checkup, the service advisor recommended the following be replaced:
    1. A/C Filter
    2. Air Filter
    3. Stabilizer link
    4. Stabilizer bar bushing
    5. Front Brake Pads (3.4 mm remaining)
    6. Rear Brake Pads (3.7 mm remaining)
    Total parts & labor cost is over Php 27k at M.I..
    Since the car is out of warranty, it doesn't make sense to spend this much. The service advisor was kind enough to suggest I try Fusion R for cheaper brake pads.
    Can anyone advise me if/where I can find alternatives for all this?
    Thanks.
    Quote Originally Posted by powerloord View Post
    1. A/C Filter
    2. Air Filter
    3. Stabilizer link
    Thanks.
    let's see...
    pinapa-hanginan ko lang ang air filter ko...
    hinuhugasan ko ang aircon filter ko..
    if your stabilizers aren't causing problems, mebbe you don't have to replace them yet..
    brake pads? ask the parts stores in pasay rotonda, paco, or banawe if they have equivalents. or, you can have them re-bonded with new friction pads..
    kuripot prince, that's me!
    Oct 2009
    bumili ka nalang ng mga nasabing parts saka mo ipakabit sa isang ordinary shop 100%
    baka wala pa sa kalahati ng 27k ung bayaran mo baka pinaka malaki na ung 10K
    I've already made an appointment sa Fusion R. Less than 5k lang brake pad set including labor. Definitely more affordable.
    pwede kaya ito rebushing?
    Sent from my Redmi Note 9 Pro using Tapatalk
    Jan 2008
    maluwag na ba? may pang test nyan dapat may konting resistance pa din pag inikot mo yung joint
    yup malaki na play bro
    Jan 2008
    palit na yan.. nasa 1.5k yata yung 555 1 pair na can't remember the price pero mura lang yan
    may ad sa carousell now.
    oem "used but good".
    a relative once tried to replace just the bushes.
    sandali lang, sira na naman.
    he had since purchased the much more expensive oem assembly.
    it's still ok, after several years.
    tiempo-tiempo lang siguro, depende sa materials used.
    do you believe in cruvens? (relative didn't use this; he used something else.)
    kinda reminds me of that serial features program on how cuban car aficionadoes manage to keep their 50s cars going... where frankencar-ing is a literal backyard and frontyard industry...
    bought 555, 1500 for pair
    pero 850 pag isa lang.
Replace Stabilizer Link & Bar Bushing, Brake Pads, and Air & A/C filters
