Page 49 of 153 FirstFirst ... 394546474849505152535999149 ... LastLast
Results 481 to 490 of 1521
    Feb 2013
    #481
    Quote Originally Posted by josekuj View Post
    Hi boss saang dealership ka po kumuha ng unit?
    Subaru Manila Bay
    Nov 2017
    #482
    Quote Originally Posted by kevindd992002 View Post
    Subaru Manila Bay
    gano po katagal wait mo for the unit? and how long din po yung or/cr
    Jan 2012
    #483
    The small screen between the tacho and speedo displays the fuel gauge, trip A&B, and the cruise control settings.
    The screen on top of the HU displays (from the left) outside temp, FC, and time in 24H format. The FC screen can be toggled between the average speed, FC (in L/100kms), range, and blank using the Info button on the steering wheel.
    Thank you sir JohnM for the info.
    Sep 2017
    #484
    Tale note though that the base model doesn't have the info display above the HU.
    Is there a way to set the time to 12H format and the date to MM/DD format? It kinda sucks to see the 24H and European DD/MM stock format.
    In the brochure, the totl has the high grade multi-display(color). I think in the base its monochrome only.
    Ive seen a youtube reviewer that say he prefers the monochrome as the high grade display can be somewhat distracting at times.
    Feb 2013
    #485
    I've waited for one month for the Dark Blue because my SA did not do any "pangungulit" telling me to reserve a unit right away. I was number 1 in the waiting list.
    I got the OR/CR 5 days after the unit was released.
    Jan 2012
    #486
    Got this quote from BGC for the base model:
    "8 inch LCD Display, Web Link (iOS & Android) Music, Yelp, Waze, Weather, Android Mirroring, Bluetooth Hands free phone & Bluetooth Audio, AUX in, HDMI, iPod, CD, DVD, USB Ready." No mention of a camera pero malamang abang na ang harness nyan and actual camera na lang ang kulang.
    I don't think we need to worry naman about blowing up our electricals with a properly installed camera. I have a third party camera installed on my Mazda plugged into one of the Body Control Modules and they still honored the warranty for some suspension issues.
    Hi, JohnM. About this post of yours, sabi ng SA ko meron "abang" for the reverse cam for the 6.5" HU sa base model. Not sure if this is entirely true, though I checked sa base model sa ibang bansa they're equipped with back up cam so Im hoping na meron nga.
    By now, i'd assume you have already installed yours pero ask ko lang kung meron ba talagang "abang" for the stock head unit or do you have to get another HU ( 8" screen that was quoted to you)?
    Also this 8" screen was it offered as an upgrade, and is it the same stock HU for the TOTL or ibang brand? Sorry for asking a lot of questions. I asked my SA about this option - wala daw.
    Aug 2004
    #487
    Quote Originally Posted by exodudz View Post
    Nagpakabit na kami ng reverse camera sa LA Auto pero di na namin tinuloy via HU. Mas sanay rin kasi si missis na via rearview mirror ang output ng camera dahil ganun din setup ng previous car nya.
    Walang abang na camera connection sa trunk door. Buti na lang nasa trunk door na ang reverse lights kaya madali lang i-tap. Ang camera naka-turnilyo sa stock location to the left of the door switch. Ni-route nila ang wire via the weatherstripping sa passenger side. Then ang power ng mirror naka-tap sa 12V plug sa dash kaya virtually invisible talaga ang install.
    Not sure kung may abang ang 6.5" HU dahil di na namin pinatuloy ang pagbaklas. May "camera timeout" setting kasi ang HU so posible talagang meron.
    Nabanggit din ng isang SA na may possible HU upgrade nga daw na sure na may abang for camera. Sabi naman ni ************ na it's going to be a Panasonic with built-in navi BUT walang Android Auto or Carplay. Kung ganun parang downgrade para sa akin so kung totoo nga ang specs di ko na papapalitan ang HU.
    If you're planning to change your HU to a third-party brand like Pioneer or Alpine make sure na kumpleto pa rin ang car settings. May mga settings kasi sa oto na via HU mo lang ma configure like signal lights and timeout ng interior lights.
    Jan 2012
    #488
    Thanks sa detailed explanation and tips sir JohnM. Very helpful. Sa LA Auto na lang din ako magpapainstall [emoji2]
    Aug 2004
    #489
    Thanks sa detailed explanation and tips sir JohnM. Very helpful. Sa LA Car na lang din ako magpapainstall [emoji2]
    LA Car pala. Ito yung nasa San Antonio Makati.
    Doon ka na tumambay sa labas while they're installing your camera. I won't advise tumambay sa loob. Mapapagastos ka lang lalo
    BTW I found this on the manual I downloaded:
    Setting 12-hour or 24-hour display
    The clock can be set to 12-hour or 24-hour display. Perform the following procedure to
    switch the display format.
    1. Place the ignition switch in the “LOCK”/“OFF” position.
    2. Press and hold the “−” button located near the clock display for approximately 5
    seconds. The clock display will then start to flash.
    3. While the clock display is flashing, press and hold the “+” button for approximately
    2 seconds. The clock format will then change.
    4. The clock display will continue to flash for approximately 3 seconds to inform that
    the clock display has been changed.
    Tried it a while ago and it works. AM/PM na ang display instead of the previous 24H
    Feb 2013
    #490
    Thanks! I'll try this tomorrow. Hindi ko pa nabrobrowse yung manual, very busy
2018 Subaru XV
