Page 14 of 37 FirstFirst ... 410111213141516171824 ... LastLast
Results 261 to 280 of 1521
    Sep 2014
    Quote Originally Posted by kevindd992002 View Post
    So medyo magastos pala gas kapag naka cruise control sa expressway kapag may slight uphill kasi kailangan niya imaintain yung set speed.
    parang eroplano lang yan, pag naka autopilot less priority na nya ang fuel efficiency. kung pwede lang ayaw ng airline yun laging umaakyat ang eroplano kasi nalulugi sila sa fuel tax
    Oct 2017
    just keep the revs under 2k...
    This I agree with - especially in city driving.
    Jan 2011
    Quote Originally Posted by Niner_seven View Post
    Way off pala yun sabi ng SA na around 10-12 combined due to the redesigned engine na 30% ligther?
    Jul 2015
    Quote Originally Posted by tuazon7 View Post
    theyll say anything for a sale, 9-10 combined ko ngayon...im more concious of how heavy my foot is and i dont get agitated when i see aggressive cars drive pass me, believe it or not it has an effect on how much you step on the gas..
    Aug 2017
    I agree on that. I do it more often. [emoji4]
    Sent from my iPhone X using Tapatalk
    Aug 2009
    10 on light city driving, 12 on highway [emoji1]
    Feb 2013
    What's a good third party backup sensor that I can get for my XV?
    Feb 2013
    Can anyone confirm of your Starlink HU's auto brightness works? Mine never adjusts its brightness regardless of the ambient light. This means that during the night, the brightness stays at full and is very blinding to the driver. I have to swtich brightness to manual mode and set it to the lowest setting. This gets really annoying.
    Can you try changing the wallpaper to something darker?
    looks like the sensor sees a bright light source...
    Aug 2004
    Do you have a manual brightness adjustment roller on the lower dashboard to the left of the steering wheel? If this is set to max brightness the HU won't dim when the headlights are on. Set it to at least one click dimmer and the HU will switch to night mode when the lights are turned on.
    Feb 2013
    I can't find any setting to change wallpapers.
    See comment below.
    Yes, I do and I think it is set to max. Ok, that makes sense. So the "auto" brightness mode of the HU depends on when the headlights are on or off and doesn't havr itw own light sensor.
    Another question. Based on the manual, the headlights level automatically adjusts depending on the car load. Non-Philippine models have the manual level adjustment roller which was purposely removed in our units. Has anyone confirmed that the headlights level really change automatically?
    Aug 2004
    Our HU has 6 available wallpapers. They can be changed under the user options. I added a new user and did not use the default.
    The base model still has a manual headlight level roller beside the dash brightness roller. I set it to the highest level and so far no one has flashed us even with a full load of adults. It's fun playing with it as one can imagine that the car has popup headlights
    Quote Originally Posted by al_kasunuran View Post
    Holy crap thanks for this.. I thought it was just me who was getting blinded by the HU at night.
    It was an AHA!!! moment. We were driving around with Waze on and the brightness annoyed me. I usually turn off my 3's display while driving as I like it dark so I had to find a solution. After going through all the menus and failing to fix the issue I suddenly remembered the dash brightness roller and how my wife told me she liked it turned up all the way. One click down and voila the HU screen darkened and Waze shifted to night mode.
    Feb 2013
    Ok, I can change the wallpaper now. The headlight trick to dim the HU worked. So auto mode switches between level 6 brightness (when the headlights are off) and to whatever level your brightness roller is set to (when the headlights are on). That'a kind of a rudimentary way of automating brightness, not impressed
    This is the first time I've driven a CVT and I'm not sure if this is normal. When accelerating from a low speed (as in after doing a full brake, e.g. coming from a high hump), the car doesn't feel powerful enough (parang hindi naka first gear) unless I step on the gas until it goes to around 1300 RPM or so.
    The same behavior happens when I'm uphill, say in a parking building where I need to drive to higher floors to find a parking slot.
    I'm comparing this to my previous daily driver (2008 Montero Diesel) wherein parang sensitive enough siya during low gears.
    *rerramos
    Yung light sensor ng XV mo na nasa taas ng windshield, hindi ba talaga siya nakagitna dun sa parang square area kung nasan siya?
    cvt will always use higher ratios...its like 12gears. nasa 3rd or 4th or 5th at slow pace... press deeper it will drop 1 or 2 or 3 gears down. its meant for minimal fuel use...
    Feb 2013
    Ahhh kaya pala! It does feel like it's using higher gears when at slow pace kaya parang walang power. So talagang ganun pala talaga siya. Thanks!
    that di 2L boxer has over 150hp and can out accelerate juts 1.8 civic 😁 in a 0-100 with 95ron.
    new xv is fast to 100 but its awd and high gc will just drag it past 100...
    Is this true for all gas cars or is it more noticeable with CVT? I just drove our Fiesta and I feel that its gas pedal is a lot more sensitive than the XV. A little pressure on the pedal makes the car pull. I'm not sure if this is due to the small size of the Fiesta compared to the XV.
    Partly to the size of the Fiesta and its DCT tranny. Subaru's CVT is softer off the line compared to Ford's CVT.
    My Fiesta Ecoboost feels more responsive on throttle inputs and feels to pull harder off the line compared to my Forester XT despite the XT being a lot quicker to triple digit speeds.
    Fiesta's dual clutch transmission is more responsive than a CVT and even with a conventional automatic transmission. The Mazda3 Skyactiv's automatic transmission is better though
    I do find dual clutch trannies to be more responsive than conventional AT or CVT. Ford's DCT needs a bit of learning to get used to it but applying throttle input the same way like an MT car helps. VW's DSG is smoother and offers a feel more like a conventional AT. VW's DSG also shifts quicker than Ford's DCT.
    How much improvement does the new FB20 engine offer compared to the older model? The previous gen XV sprints from 0 to 100 kmh in just over 10 seconds.
2018 Subaru XV
