Page 33 of 82 FirstFirst ... 2329303132333435363743 ... LastLast
Results 641 to 660 of 1640
    Sep 2010
    #641
    Quote Originally Posted by Arvin Cristi View Post
    partner pa grasahan mo na lang sa kanila uli yan, yung grasa kasi na ginagamit sa mga casa is kumbaga... generic all purpose grease, malamang MP3 grade pa yun, matigas na hindi malagkit masyado.... or you can spend some money and go to a gas station and request for a greasing with MP2 grade grease na moly based or something better...
    ang tackiness(lagkit) kasi ng moly based grease mas maganda or mas mataas kaysa sa mga ordinary everyday gas station grease...
    the rease i use kasi is the one i use for my machineries
    Sir Arvin, thanks for the advise.
    Jun 2008
    #642
    sir dad'z, actually yung akin may salyada na din, dinaya na lang namin with the grease, ginagamit na namin kasi is grade 2 with moly-di sulfide para malagkit and water retarding siya, so far medyo nawala na yung salyada, pero candidate na yung mga cross joint ko for replacement mas lalo na yung pang front prop
    Salyada is a common thing in rear differential rigs, even sa automatic meron din yun nga lang because of the smooth transfer nag auto transmission kaya hindi masyadong ramdam but kung actual check sa propeler ma feel ang salyada.
    #643
    Sakin din may salyada. 1month palang auto ko meron na. Same as sa montero ng tita ko. Matic yun. Meron din.
    Is this normal? Hindi ba masisira?
    Jun 2008
    #644
    My truck have salyada for a long time never have it check and so far havent grease it but wala naman po akong problema sir same thing with my previous strada's and pajero.
    May 2007
    #645
    sir tanong ko lang saan kaya makakabili ng roll n lock na brand na roller lid for our strada?
    compare sa carryboy no drills required kasi ito. sana meron dito sa atin. TIA
    May 2007
    #646
    Aug 2007
    #647
    Quote Originally Posted by njeudela View Post
    *janrye26- what's the specs of your tires? 265/75/16? really like the stance of your strada
    opo sir. thanks
    Jun 2007
    #648
    sir janrye suggestion lang...baka you want to try coloring your door handles inserts into black...parang navivisulize ko kasing mag cocontrast with the mags....
    Oct 2004
    #649
    +1. Keeps the theme going, sir.
    Dec 2009
    #650
    good eve po sir,
    tanong lang po, paano po yun ginagawa, yung pag change color ng door handles from chrome to black ?
    thanks
    Jun 2007
    #651
    ^I was actually referring po sa inserts sir...However if you want to have your door handles black, you can actually paint it...another is that you can also search someone that has a GL unit and wiling to have your chrome door handles traded with his plain black ones....HTH...
    Apr 2006
    #652
    re: Headlights Switch (hi/low)
    Inaaalign ako ng headlight ko kanina (sinundan ko ang instruction ni Arvin kung alin turnilyo ang pipihitin).. Napansin ko lang, pag switch ng high beam medyo nababawasan ang liwanag sa low-beam (nag off ang low beam) pero kung naka low-beam ka lang at mag FLash lang ng high-beam parehas sya naka sindi. Normal lang ba eto na automatic mag off ang Low-beam natin pag nag high-beam tayo. Pwede ba modify ang wiring na pag nag switch tayo ng highbeam eh yun low beam naka on pa din ;)
    yun mga nag upgrade sa Angel eyes, ganyan din ba ang switch nyo? pag high-beam patay yun isang ilaw? or ginawan nyo ng separate switch? baka me diagram kayo dyan ;)
    thanks
    Aug 2007
    #653
    hahaha. oo nga ano? pwede!
    Sep 2006
    #654
    tekken - yup lahat ng h4 bulbs ganyan namamatay tlga ung low pag nag hi
    Aug 2007
    #655
    Quote Originally Posted by t3kk3n View Post
    thanks
    ganun talaga sir, pag naka HI ka, yung LOW naka off..
    pwede namang pagsabayin yung HI & LO ng angel, palagyan mo lang ng relay
    Apr 2006
    #656
    *martin/nismo
    Thanks. Pero pwede ba lagyan or modify ang stock h4 bulb na pag nag hi beam ako hindi mag off ang Low beam ?
    Jan 2008
    #657
    *martin/nismo
    partner pwede naman gawin, ang problema lang is yung paglagay ng bypaa line going to the low side coming from the high side. baka kasi magkamili ng paglinya mag salubong yung current sunog ang wiring at relay ng mga ilaw niyan, it is doable, pero i don't see the point as to bakit mo pa kailangan gawin?
    May 2008
    Aug 2007
    #659
    Quote Originally Posted by jashty_enzo View Post
    inayos ko lang...
    Sep 2006
    #660
    well diod po lang lalagay sa wiring ata hahaha
TSCP Strada Mods [continued 2]
