Page 52 of 139 FirstFirst ... 24248495051525354555662102 ... LastLast
Results 1,021 to 1,040 of 2775
    #1021
    Quote Originally Posted by kraig_ethan View Post
    yun sana last recourse ko bro. thanks master sael.... may nag suggest ng activated carbon kaso di ko alam kung saan kukunin.
    bro pinaganda lang ang name nyan "activated carbon" pero uling pa rin yan hahahahaha, tirahin mo na sa uling bro....
    May 2007
    #1022
    Quote Originally Posted by mdksael View Post
    totoo nga bro... activated carbon: http://en.wikipedia.org/wiki/Activated_carbon
    but for the stain removal... detailing perhaps?
    #1023
    hahahahaha galing talaga ni ian....
    anyway bro ian thanks for the map.........got it....see you
    #1024
    share ko lang si "azul"
    Aug 2009
    Feb 2006
    #1026
    Hi Guys,
    New owner lang po (2010 White Strada GLX). Mod ko lang po yung tires from stock 205/80/r16 to 245/70/r16 Dunlop Grandtek AT3. Pansin ko lang po medyo tumagtag yung ride. Talaga po bang matagtag yung ride ng Strada pag ganito ang tires. I set the pressure to 32/32 ganun pa din. Then 29/28 medyo umayos, pero matalbog pa din po yung likod. Ano po kayang magandang gawin para medyo gumanda yung ride. Kasi naawa ako sa baby ko na naka-upo sa likod, pag ndi po aspalt yung road(pavement lang) matalbog sya at parang tumatalon yung nasa rear bench seat ko.
    Thanks...
    Dec 2007
    #1027
    Quote Originally Posted by calypso_gun View Post
    Hi Guys,
    Thanks...
    welcome to tsikot and sa TSCP threads sir!
    personal experience ko when I changed tires from stock papuntang 265/70/R17 Mickey Thompson Baja ATZ, mas gumanda ang ride. sa tire pressure na 32, talagang matalbog yan... kung wala ka naman mabigat na dala, try mo as low as 25 psi para malabot ang ride (ganyan ang pressure ni docglen)
    and I installed pala a top-up bedcover... since medyo mabigat siya, mas gumanda ang ride... comfortable matulog sa rear seat ang baby ko.
    intay lang natin ang opinions ng ibang BOSBs...
    Dec 2008
    #1028
    Sir Sael,
    Please post pics with a better view of your Skid (Bash) Plate?
    Pati na din audio set-up mo? hehe
    Dec 2008
    #1029
    Hi Guys,
    Thanks...
    Sir,
    Tama si TP. Matalbog talaga kung 32 psi. I put 28 psi in the front tires and 26 in the rear, and I use 275/70/16 HT Tires.
    Also, when I loaded 3 sacks of garden soil or a sack of gravel on the truck bed, gumanda yung ride - siguro nagbigay ng dampening effect yung cargo.
    Feb 2006
    #1030
    salamat po mga sir. Plan ko din po kasi maglagay ng bed cover. Pero siguro pa member muna ako para may discount Hehehehehe...
    Sige po mga sir, try ko po mag 25 kapag walang load. lagi naman po akong may bitbit na air pump kaya pag magload ako ng 2-6 sacks of rice taas ko na lang yung pressure. Maraming salamat po sa information.
    One another question po. May nakita kasi akong mga adjustable dampering system sa net para sa ating mighty strada. May nakasubok na po ba nun? Dito po sya makikita.. http://www.4wd1.com/Mitsubishi-Triton.htm
    #1031
    pareho saken nagpalit din ako ms montero mags 17, 265 ok naman ang ride nya, but i also had lid cover. baka ito yung nag neutralized nun talbog hehehehe....(tire pressure 30psi both)
    Apr 2006
    #1033
    Hi Guys
    Upcoming Strada owner palang ako.. the car has been ordered/reserved, probably nextyear ma release na sya Im getting a GLX 2010 Strada. and I already saw some upgrades here specially the Mags and tires. Will there be any issues if ill be upgradiing to a 225/70/R16 TIRES or just simply upgrade to Monterro mags and tires
    Thanks in advance HOpe to join the club nextyear once my unit has been released
    #1034
    sir pol pol, mukhang hindi maganda ang pagkadownload ko, hehehehe, you can also check my facebook acount "sael requierme" more pictures there....
    Jan 2008
    #1035
    sa 265/70r16 na goma advisable tp is 28psi rear 30 front. pero since pups ang sasakyan natin, magaan ang mga likod natin plus matigas pa ang mga molye. so pwede na din i 25 psi ang rear, problema nga lang diyan is early tire wear...
    i'm using cooper STT mud terrains 265/75r16. rear ko is 30 front is 32. pero this is because i'm always carrying loads sa bed ranging from 1/4 ton to 1 ton.
    pero pag bumigat ang bed mas masarap ang ride talaga kasi nag lalaro na ang mga leafs, para ka nang hinehele sa daan
    Aug 2008
    #1036
    Peeps,
    Where can I get yung parang net na may apat na hooks? Strechable sana so I can load tall cargos. Lagyan ko ng trapal then the net over it para secure ang cargo.
    I've been looking around sa hardware stores wala akong makita. I'm plannin to make one pero I can't find the stretchable ropes.
    If I'm not mistaken, I think the closest thing was yung kay Sir Arvi's net.
    Aug 2009
    #1037
    ganda naman... will check your facebook na lang para mas malinaw.
    Apr 2009
    #1038
    Hi Guys,
    Thanks...
    sir mine is only 28/27 (f/r) considering i have a big engine(3.2L) and fat butt (210lbs.)..
    #1039
    Quote Originally Posted by Idoy View Post
    Peeps,
    bro, sa ace hardware marami nyan bro..............
    Feb 2006
    #1040
    Sir ask ko lang po how much and saan po kayo nagpagawa ng front detonator.
    Thanks..
TSCP Strada Mods [ARCHIVED]
