Results 1,091 to 1,100 of 3844
- Apr 2010
- 23
April 29th, 2011 11:43 AM #1091Thanks po sir Jonlandayan, tanong ko na rin po saan po loc nyo... gusto ko sana pa tingnan/asses mb ko kasi parang madaming symptomas ng lumalabas e.
yung cleaning po ba ng tappet would require top overhaul? meron po bang mga parts na papalitan?
- Feb 2009
- 102
April 29th, 2011 05:48 PM #1092Sir Jolandayan, maraming salamat! tanong lang ulit pano ko ba makikita yung fuel pump dun sa gilid ng injection pump? nakadikit ba sya sa injection pump assembly? saka kung saan side sya ng injection pump nakalagay? salamat uli.
* sir arthem, kay apic ka ba mag papalinis ng valve tuppet? update mu naman kami kung magkano aabutin parts and labor. saka kung gano katagal.
- Feb 2009
- 102
April 29th, 2011 05:51 PM #1093Mga ka MB nabasa nyo naba ito sa kabilang forum?
Diesel owners that add 2T oil to fuel Not much on this here so I thought I bring it up, Pretty common practice in the states on older diesels, I run it in my Elgrand 3.2 turbo diesel when I first got it the engine use to shake a lot more than I liked so I went ahead and started using 2T oil. First thing I noticed is the engine was so much quieter and smoother after the first full tank, I got a little bump in fuel economy as well and it eliminated the harsh shut off shutter I would get when I would turn off the engine.
Let's just get the basic question over with,
Will it hurt my engine, NO if used as described 200:1 mix ratio. example 17L tank = about 3oz 2T.
Will it clog my fuel filter, NO
Will it mix with diesel, Yes
Can you use it with Bio-diesel, Yes
Can I just add it every other tank, or whenever I want, Yes
What's the best 2 stroke oil to use, The cheapest is the best no synthetic.
Do I have to get the mix exactly right, No you can be a few oz or so over without harming anything. (Brother in law dump a 8oz bottle in the Elgrand had no issues) Told him 3oz)
Should I use this on Common Rail diesels, Yes but nothing made after 2006 (which is the 2007 model)
Does it give you more horse power, NO
Does it change the Cetane rating, NO
Also added it to my friends Kia Prego which you could hear comming down the block due to engine rattle, He was also very impressed with how smooth the engine became after adding it. He's been using it since Last November and plans to keep using it.
Also did it on the family 1999 Starex, major improvement on that thing as well it use to shake like crazy at idle, I would say about a 80% improvment after 2 months of use. So for 100P to 60P for 8oz bottle it's not a bad investment. Especially for your fuel pumps life.
Mix ratio is 200:1 by volume of fuel not ment for 2007 Up diesels.
Here's a study done on it
http://rivrdog.typepad.com/files/cop...-version-3.pdf
- Feb 2009
- 102
April 29th, 2011 06:01 PM #1094dito ko sya nabasa
http://tsikot.yehey.com/forums/showthread.php?t=79879
Gusto ko sana testingin sa MB ko kaya lang medyo natatakot ako eh.
April 29th, 2011 06:21 PM #1095
April 29th, 2011 06:46 PM #1096
mga sir okay lang po ba palinis lang ang nozzle tip ng mb atsaka ano po yung pressure niya
April 29th, 2011 06:54 PM #1097
*birador.....dko alam sir,sa radyo lang kasi namin ginagamit yang larsen antenna.sa fm nasubukan ko,lakas ng sagap.try mo wala naman mawawala e.
*mixxture....yung paglilinis ng tappet di naman masyado madugo,aalisin o iaangat lang yung cam shaft para matanggal yung tappet.yung paglilinis at pagkakalas ng tappet ang mabigat.karaniwan lang na pinapalitan ay yung rubber gasket ng valve cover kung matigas na,kung ok naman at wala katas pwede pa ulit un.sa bulacan yung place ko.pero alis nako bukas ulit.partner ko maiiwan dun w/c is mas mahusay,hehehe.
*wheeljack2....may post ako injection pump sa #72.sa gilid yun may plastic hose.tingnan mo na lang,two 10mm na nut lang at matatanggal na iyon,ingat lang at pumipitk ang spring,alalayan lang pagtatanggal.
ok yang mixture na yan a.maganda nga sa fuel system yan kasi may lubricant talaga.lalo na sa crdi.kaso di kaya mag usok ng puti yun.parang tricycle.sa owners manual naman ng MB regular gasoline o kerosine naman yung hinahalo,kung malamig ang panahon.
*mb100...sir di nakukuha sa linis yun,sumikip man ulit sandali lang balik na sa dati.baka sa bandang huli mas malaki pa ang gastos,kung bibili kayo ng tip yung black na delphi ang bilhin,blue na kasi ang labas ngayon,parang di tumatagal e,..obserbation lang nung partner ko yan,sa inyo pa din ang desisyon.at wag nyo pacalibrate yung tip bago ikabit,dagdag singil lang yun.calibrated na yan paglabas ng pabrika.kung may konti pa lagatak,yaan nyo lang at lalapat din yun ng sarili nya.payo lang yung akin kayo pa rin ang may desisyon.kahit kay george nyo papalitan isasalpak lang yan ok na.ewan lang sa iba.
ang bilis ng araw,isang buwan na pala.aalis na ulit ako.ingat sa byahe mga kapatid.stay proud.!
- Apr 2010
- 23
April 29th, 2011 07:56 PM #1098Thanks again sir jonlandayan, naka usap ko na po si sir ellie, pa tingnan ko sa kanya mb ko once na mapagana ko na yung clutch
, medyo nadala kasi ako sa apic nung pinapalitan ko yung belt ko e
, any members po na taga rizal area?
- Jan 2011
- 122
April 29th, 2011 11:19 PM #1100* sir jonlandayan gud luck and happy trip sa iyo
ingat sa mga salisi sa naia, hehe si kim chiu kasi nadukutan doon eh
They're hell-bent on sustainability kasi... even at the expense of a shorter lifespan from their...
BYD Philippines
