Results 11 to 20 of 616
December 29th, 2010 01:33 PM #12
December 30th, 2010 12:01 AM #13
Sir Thank you. Ok na yung alarm ng sasakyan ko. Sa 2010 na 4x2 Manual, yung blue LED na nasa dashboard cannot be press but there is a small red switch below the steering wheel near the door hinge and the clutch pedal ang sinubukan kong i-press while nasa "on" yung car key then i heard a beep tapos ok na yung alarm nung car and yung blue LED hinde na palaging naka ilaw. Nailaw nalang kapag naka lock ang car as expected.
Baka ganito lang din ang issue ng Monty mo Kelvin3000
December 30th, 2010 03:57 PM #15
Para sa mga naghahanap, ito yung procedure for activating/deactivating some of the default settings ng code alarm ng montero natin.
Please note that this will only work for the 2008 and 2009 models. Iba na kasi ang alarm module ng 2010 model so hindi na yata siya customizeable gaya nung older models like ours.
Tsikot Member Rank 4
- Jan 2003
- 2,979
- Nov 2010
- 4
January 24th, 2011 12:51 AM #18sir pahingi naman po ng alarm manual for 2010 montero sport 2.5 at 3.2 please.. need lang po talaga.. wala po kasi sa manual booklet ng sasakyan eh. maraming salamat po
- Jun 2011
- 4
June 25th, 2011 09:50 PM #19Sir pasend din po manual ng 2010 Monterosport para sa alarm, nagpapanic kasi maya't maya nag aalarm e, thanks.
June 25th, 2011 10:01 PM #20
pareho ba ang alarm ng 2010 MS at 2011 MS VGT?
i have a copy of the manual of the alarm for the 2011 MS VGT
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
