Results 1,731 to 1,740 of 1770
August 18th, 2010 10:16 PM #1731
August 20th, 2010 10:48 AM #1732
August 20th, 2010 08:48 PM #1733
If the fuel filter is the culprit (either trace of diesel-water mixture or simply dirty), definitely replace. Main fuel filters are not designed to be cleaned.
Now if you do find that it's either of both reasons why your fuel filter had to prematurely replaced, you better consider bringing down your fuel tank and have it cleaned too. Palinis na din yung fuel lines mo.
- May 2009
- 119
August 23rd, 2010 09:55 AM #1734hello good morning fellow tsikoteers....
have anyone of you seen or tried the new diesel from Petron it is Petron Diesel Turbo and sa Shell naman yung Shell Diesel Velocity nila...pashare naman sa mga nakapagtry na kung ano feel ang difference with the oridinary diesel we are using..thanks
- Aug 2009
- 349
August 25th, 2010 12:50 AM #1735good day! mga sir..
\ Magkano ba usually mag pa bleed change brake fluid ng xuv natin?
- Aug 2010
- 3
August 26th, 2010 02:19 AM #1736I own a 2002 Xtrm, nahinaan ako sa stock na ilaw so nagpalit ako ng 80/100 na osram nung mga 2006. Recently napilitan akong bumalik sa orig na 55/60 kasi "nasulog" daw yung relay ko because of the high wattage of the 80/100 sabi ng mechanic ko. Ngayon naman sobrang nadidliman na ko sa 55/60, ayaw ko naman mag HID. What do you guys suggest na pamalit ko sa stock bulbs?
August 26th, 2010 02:27 AM #1737
August 26th, 2010 08:52 AM #1738
- Feb 2010
- 194
August 26th, 2010 10:48 AM #1739
- Feb 2010
- 194
August 26th, 2010 10:56 AM #1740
i had mine replaced, but at the manila end. the las pinas end was closed at that time, kasi....
costal expressway
