Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    #21
    o.t. lang po...
    bro. boybi... may nakita ako sa sulit 1 tera- toshiba 3,250 lang.... good buy na ba yun? nabagsak kasi nung office mate ni wifey HD ko nasira....
    Mura na yan. Around 10k ko pa nabili 2tb na WD sa HK.
    Signature
    Jul 2012
    #22
    Try to replace muna the enclosure. Mura lang naman.
    #23
    Quote Originally Posted by deafault View Post
    The enclosure doesn't have anything to do with the hard disk inside. It's just a casing, no electronic parts.
    Signature
    Jul 2012
    #24
    You probably didnt see it pero meron siyang ganito. In my case yan ang nasira so i had to change its enclosure kasi wala nabibiling ganyan lang (dont know what you call that part).
    #25
    Walang ganyan yung WD Passport. Walang detachable component yung hdisk. Casing lang ang natatanggal.
    Signature
    Jul 2012
    #26
    That's odd. Can you post a pic of the hdd?
    Does it have this?
    Jul 2012
    #27
    #28
    This is the hard disk inside the casing.
    Signature
    #29
    I've already taken it out and still cannot be recognized by the PC. There were times it will connect and I was able to transfer some files but it will just disappear.
    Signature
    Oct 2011
    #30
    faulty hardisk kaya hindi na ma recognize. sometimes it will and sometimes it won't. i back-up and retrieve my files and do a clean format sa hardisk ko.... pero tingin ko lalabas ulit ung ganyan problem na un in the long run.
    Jan 2009
    #31
    Looks like the USB3 interface is actually part of the hard disk PCB. No way to retrofit that to a SATA or even an IDE interface.
    Found the following video. It appears that newer WD Passport drives have this USB-integrated module in the hard disk controller.
    Apr 2010
    #32
    Bakit hindi madetect yung WD My Passport external hard drive na kakabili ko lang kahapon when plugged sa TV?
    Sent from my ASUS_Z011D using Tapatalk
    Jan 2018
    #33
    Quote Originally Posted by myas110 View Post
    Try to change the partition method to MBR
    Apr 2010
    #34
    Quote Originally Posted by SpinCycle View Post
    What is MBR? and how to do it? Kasi I'm planning to change it from NTFS to FAT32 (but the option FAT32 is not available sa windows... need ko pa ng third party app to do it)
    Jun 2015
    #35
    Possible na incompatible disk controller. I have a USB SATA hdd enclosure na nadedetect sa pc but not by our TV. 80GB lang ang laman nun and it works flawlessly sa Windows and Linux. Try mo sa ibang TV yung hdd mo.
    Sent from my ASUS_T00J using Tapatalk
    Apr 2014
    #36
    Parang common issue ata ang di pag detect ng WD drive at samsung tv
    WD Elements 1TB HD Compatibility Issue with Samsung LED TV - [Solved] - Storage
    Apr 2010
    #37
    Quote Originally Posted by chronicle View Post
    Okay.. so, common issue sa WD External hard drives yung compatibility sa mga Samsung TVs. Or baka dahil outdated yung firmware ng TV namin kaya hindi compatible? Or compatible lang siya sa Smart TV?
    AFAIK, yung ibang external hard drive (I guess it's a Seagate) ok naman sila, detected naman.
    Will try it onceI go back to Manila. Thanks
    Yes pwede outdated yung firmware ng TV. Might as well update that to eliminate as a cause.
    Sent from my SM-G965F using Tapatalk
    Apr 2010
    #39
    ^ sa bagay... I opted not to format ulit yung external hard drive.. instead I bought a 32gb 2-in-1 USB (OTG) para dun ko na lang i-copy yung movies and at the same time, I can use it sa mobile phone ko.
WD My Passport external hdisk can't be detected
