Originally Posted by
philmagi
dvidoc,
Hi! Beleive or not beleive, I will be posting emission test results not for the bet, but for all its worth to those in the HHO project. Thanks for reminding me and will take the opportunity to do some testworks too, due to sme other issues. I dont want to go into arguments as I am relating my experience only. However, I was told that the oxygen sensor signal can be processed electronically/ mechanically by the use of an electronic fuel injection enhancer (EFIE) or mecahnically with O2 retractor/isolator before it goes to the ECU for continuous up/down trimming to the ideal 14.7:1 AFR. This is sort of piggy back that may result into fooling the ECU mapping from open to close mode, e.i the O2 differene in the exhaust gas and atmosphere. Remember the "S" curve in Voltage and lean/rich graph of the ECU program? I just did the mechanical version, and an EFIE (electronic version) is arriving. The current method seems to fool the ECU, and apparently working.
I understand ECU limp mode atitude to protect the AFR in the ideal mode as well as the engine, but the issue is to enhance the O2 sensor as to fool the ECU - it is a stupid computer. In addition, the MAF sensor signal, a voltage varaiant not the frequency variant is also enhanced whith electronic I made from DEECO parts in RAON. The coolant temperature seems not to be bothering the results except on cold startup, but the MAP sensor (hot wire to measure air volume flow and temperature to indicate air density). On the crank position for ignition timing i had to adjust personally for best results. On speed, it does have an opening for best HHO operation, ie. cruising and max of 100 kph.
I would want to order an "opec" circuit board to over ride the ECU programming but needs flashing of the OEM programming, nit OBD I or OBD II, for polltion comtrol. I am happy with the current setup and is still learning. If I need help, i will ask for it. Whether I am an expert or not will not then really be an issue.
Thanks for reminding me of the test works and to ask for help.
philmagi.
