Quote Originally Posted by xykosomatik View Post
based on the readings i provided, this setup is not producing H from H20, but producing HHO from H20.
Pure terminology BS. The electrolysis process is still simply producing hydrogen & oxygen in gaseous form. Hence you are producing H and O. HHO is the same thing as H & O. HHO is NOT any different.
A pure stoichiometric mixture is most easily obtained by water electrolysis, which uses an electric current to dissociate the water molecules:
electrolysis: 2 H2O → 2 H2 + O2combustion: 2 H2 + O2 → 2 H2O The energy required to generate the oxyhydrogen always exceeds the energy released by combusting it. (See Electrolysis of water:Efficiency).
yeah, sure it says the energy to produce the HHO is higher than the energy generated by HHO, but what if the energy required to produce it comes from wasted energy? basically you're getting something from nothing (something productive from something wasted)..
Wasted energy? Go ahead and find your source of wasted energy that you can harness into splitting water into hydrogen & oxygen. But think carefully. Won't that harnessed "wasted-energy" power be more efficiently used directly to turn an electric motor or power a light or stored in an electrical battery?
It is easy to make assumptions but make sure those same assumptions aren't contradicting themselves.
