Results 21 to 30 of 32
November 14th, 2020 05:38 PM #21
November 14th, 2020 05:49 PM #22
Thanks bro. Will have to ask the installer kung may available na UV light.
Sent from my SM-T865 using Tsikot Forums mobile app
- 54,291
November 14th, 2020 10:17 PM #23
- Oct 2008
- 380
November 14th, 2020 11:58 PM #24question lang po, mas makatipid ba sa kuryente if we will use a water dispenser versus old school way na :
a. hot water, every morning init kami using a electric kettle then lagay sa thermos. one iniit is good for the day na po ito;
b. cold water, lagay ng lukewarm water sa ref then pag gusto inom ng cold, get pitcher sa ref then pour sa baso.
- Nov 2019
- 1,441
November 15th, 2020 12:34 PM #25If I were to ask at may budget, better to buy branded and tested ones like GE or Panasonic if meron. I bought kyowa, worth 8k din. Akala ko matibay due to price, 6 months lang bumigay compressor, pinapa warranty ko. Reason bakit bumigay is hindi daw talag matubay compressor mostly ng local brands. Bibigay talaga lalo na if lagi g may low or high voltage sa electric lines nyo. Kinabit ko nalang sa AVR ang unit, ok naman so far. Mag 2 yrs yung unit next year July, sana AVR lang talaga solution para magtagal ang compressor nito.
November 15th, 2020 01:03 PM #26
Yes, mas matipid yung suggestion mo. But depende pa rin.... Kung maya-maya bukas ng ref to get a glass of water, it will consume more electricity. And then you will have to replenish the water in the pitcher/jug multiple times a day and syempre, palalamigin ng ref yan.
In reality, zero-sum yan.
FWIW, you are buying a water dispenser for the convenience. That's it. Just replace the 5-gallon jug every couple of days and you can have instant hot/cold water anytime.
What I do is, I have a timer setup on both the Hot and Cold circuits. Yung Hot water, available lang from 6:00-8:30am (breakfast time) while the Cold water is available only from 7:00am-9:00pm. Anytime during the day kung kailangan ko mag-init ng tubig to drink coffee (minsan lang), meron akong routine to turn on the Hot water for 20 minutes only, then patay sya ulit until the following morning.
4 water dispensers in our compound.... all are local brands.. Kyowa, Camel, American Heritage (or Home), etc. Never bumigay compressors. May isa lang, medyo natunaw connector ng heater (assembly defect).
In other words, they're pretty reliable.
Pero, sabi mo nga... ang problem sa inyo is electricity. Any appliance won't last long kung unstable electricity supply mo.
- Oct 2008
- 380
November 15th, 2020 02:27 PM #27Last edited by _Cathy_; November 15th, 2020 at 05:37 PM. Reason: fix quote
- 54,291
November 15th, 2020 02:31 PM #28
November 15th, 2020 05:03 PM #29
Typically, no. You will have to check the specifications of your water dispenser.
I see models ranging from approx. 300W to 700W.
The compressor side usually consumes 65-85W, give or take. On the Hot side, however, those that are "fast-heat" or "fast-boil" usually consumes 400-550W.
The one we use at home (Camel), takes a while to heat (appox. 20 mins) because it only has a 190W low-power heater.Last edited by _Cathy_; November 15th, 2020 at 05:38 PM. Reason: fix quote
- Nov 2019
- 1,441
November 15th, 2020 07:42 PM #30Solid Panasonic ref namin, running for almost 15 yrs na. So solid yung compressor ng panasonic even on an unstable electric voltage. That’s the reality sa place namin, need to find solid product para magtagal sa ganitong unstable electricity. Yung Carrier AC namin, hindi nagtagal ng 1 yr. Nag activate daw failsafe mechanism ng controller kaya need reset. Every visit ng technician just to reset the controller is too much. Nag give-up na ako sa Carrier AC namin. Good to know working pa rin tong mga products if stable ang electricity. Yung GE AC namin, good pa, running 2 yrs na, binili ko as 2nd hand from in-laws.
Disappointed lang ako sa Compressor ng Kyowa dispenser namin.
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
