Results 1 to 14 of 14
    Jun 2006
    guys tanong ko lang kung ano at paano daat gawin sa machine pc ko kasi kahapon na virus pc ko then yung wallpaper nya napaliytan ng blank white. na run ko na anti-virus ang nawala na yung virus but problem is hindi ko mapalitan yung wallpaper ng blank white.
    Sep 2006
    Quote Originally Posted by jonski View Post
    Sure ka ba na may virus yung PC mo? Aside from a blank desktop wallpaper, what other problem(s) have you observed?
    Feb 2005
    Jonski, the virus might have modified your registry or DLL settings that is related to the DISPLAY option inside the control panel. If you're very familar with the Windows registry and you know your way around, inside and outside the registry then you can try and look for the modifications that the virus made and undo it.
    ADD:
    Run regit. Once inside the registry, the wallpaper settings can be found at:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\System
    "Wallpaper"=SZ:C:\WINDOWS\desktop.html
    Delete this. HOWEVER, please backup the registry before you delete anything.
    Try to run an on-line virus scan. Most of the time, these on-line scans can find viruses that youre installed anti-virus program would not be able to find.
    However, I suspec that you have some sort or variat of the WM/Wallpaper Word macro virus. Question: is the wallpaper a B&W picture of a skull? If it is, then you definitely have the WM/Wallpaper virus.
    If this is the case re: WM/Wallpaper virus, try these:
    1. Delete the file "c:\windows\temp\sk2.bmp". It can also be sk1, sk3 and so on so you need to look for these carefully.
    2. Open Win.ini and look for any reference to the named file above. Better yet, remove the wallpaper value.
    3. If you're running an autoexec.bat file, try to find the modifications there as well.
    Good luck.
    Jun 2006
    Quote Originally Posted by Kikkomann View Post
    so far wala naman na ibang problem ba yung wallpaper lang.
    nicolodeon
    hindi ko kabisado windows registry...
    Mar 2005
    nakow wag mo gagalawin registry kung hindi ka sanay. wait for a fix. parang dalawa na ata kayo dito may ganyan problem. baka bago virus.
    Jun 2006
    reformat and reinstall...
    baka kailangan lang i-activate mo yung "active desktop"... if not,
    try to download and install NOD32, then update the virus database and scan..
    other virus remain if reformat lng ang gagawin... fdisk ang better jan... fill 0s talaga pra clean installation...
    Jul 2006
    Would it be solved by restoring to an earlier point? (System Restore function)
    Jun 2006
    Quote Originally Posted by mbeige View Post
    il try that later. check ko muna otherways.
    Aug 2006
    Have your tried changing monitor?
    I suspect it is just a monitor problem, It could be the monitor cable that is missing one color signal.
    Jul 2006
    Go to Safe Mode then run again all the anti-virus & anti-spyware programs... then try modfying the wallpaper...
    I think its a good suggestion for Microsoft to provide a dialog box to bring back the appearances & other settings to default... parang sa mga broadband routers.... hmmm....
    Oct 2005
    Ganyan din nangyari sa PC ko di mapalitan yung wallpaper. tinry ko anti-spyware pero di pa rin natanggal, gumamit ako anti-virus may nadedetect na virus at nililinis pero after ko restart PC ko nandon na ulit yung virus. kaya reformat ko na lang. Sa limewire ko yata nakuha yung virus kasi nung natapos ko na yung download ko don nagloko
    Jun 2006
    Quote Originally Posted by magilos View Post
    pareho pala tayo kasi nagddownload din ako initialD then nagka virus pc ko.
virus?
