Results 1 to 11 of 11
    Can I use a car battery for the UPS to increase its running time when in battery mode? Can the UPS be able to charge a higher capacity battery?
    Yes a UPS can charge a larger battery. But I suggest using a deep cycle storage battery instead of a car battery for this purpose if possible.
    BTW the UPS will take a longer time to charge the bigger battery.
    What's a deep cycle storage battery and where can I buy one?
    Deep cycle storage battery is the type of lead acid battery for large scale UPS use and even in alternative power systems. I think major battery outlets would have it.
    Difference? Regular car battery gets damaged if you drain nearly all the power from it. Deep cycle batteries don't get damaged.
    Are these available in Ace Hardware or Handyman?
    ^On malls, not the big ones (>20AH). Deep-cycle batteries are kinda specialized type and are only available from those who sell batteries for golf carts or other equipment such as motorized wheelchairs or mobile x-ray machines where high-capacity is required. In one exhibit, I saw that Motolite produces them. They are usually fully-sealed so that they can be used in any orientation, unlike "sealed" car batteries.
    I've tried car batteries for my UPS and they work fine. Try to look for a battery that has a long reserve capacity (RC) It is usually rated in minutes. Having long RC will give you longer minutes to power your UPS. Deep cycle is ok because it ususally has a long RC and it can last so many charge/discharge cycle compared to a regular car battery.
    Mar 2005
    don't use car batteries.
    motolite has VRLA suitable for UPS applications. check their website. also called to inquire they have them in stock.
    Quote Originally Posted by Psylocke View Post
    Where did you call? Meron kaya nyan dito sa Tarlac?
    Mar 2005
    called manila.
    si ED battery pwede daw nya i-order.
    Meron kayang deep cycle batteries for emergency lights?
Using a bigger battery for UPS?
