Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    So for the last couple of years I've been buying micro USB cables and USB-C cables around ₱100 to ₱500 each. And they would only last a couple of months, sometimes just a couple of weeks.
    Maybe because they are unknown brands? Any brands you know that's reliable? There are cables out there that's almost ₱1k. I wonder if that will last longer or just couple of weeks only.
    Please Re recommend a brand that can last for a long time.
    Have had good luck w/ Remax.
    ^ Remax user here, mine's already on it's 2nd yr.
    Sent from my SM-T705 using Tsikot Forums mobile app
    Jun 2015
    The cable that came with the Bavin 3-port charger that I bought around Christmas time last year is still working fine. It's the longest lasting cable I got considering it's used daily.
    Sent from my ASUS_T00J using Tapatalk
    Thanks for the suggestions. So it doesn't need to be expensive to be durable.
    Jan 2013
    I'm using Tronsmart microUSB cables, matibay naman silang lahat. Cheap but high quality tapos may 3/5 pack pa. Sa lightning naman either DevilCase or UGreen, basta MFi certified.
    Katakot yung Type C, nasira yung Chromebook ng isang Google Engineer dahil sa third party (OnePlus) Type C Cable na nabili niya. Parang hindi pa nila naperfect yung Type C standard.
    Google engineer: Bad OnePlus USB-C cables could damage your phone | Trusted Reviews
    Sent from my E6683 using Tsikot Forums mobile app
    Jun 2012
    Quote Originally Posted by LancerA174A View Post
    Tronsmart din ako. Yung 5 pcs nya na isang pack lumalabas na halos 150 pesos lang isa. Matibay naman
    Sent from my SM-A9000 using Tapatalk
    i got tronsmart type c. yup matibay sya pero bulky. hindi kasya since may phone case ako. i trimmed it to fit. problem naman is madali sya madetach. stopped using it and just used magnetic cables. very convenient. mura pa at 300 pesos (generic). Wsken brand is more durable at a higher price.
    For microusb naman I use Anker and Aukey (cheaper version of Anker) but personally it's of the same quality.
    I simply got a Samsung typeC-micro USB adapter. More flexible. You can borrow anyone's charger.[emoji4]
    I usually buy the cheap P80-100 USB but it only lasts a few weeks. This is what I got from Amazon because it has good reviews:
    I always use Samsung cables. May warranty and generally they are sturdier and charge faster than the aftermarket brands I've tried. At 500 per cable, it's not that expensive too.
    Where did you buy?
    Where did you buy?
    Samsung mismo.
    Wow thanks. Didn't know it's just 500. Kala ko parang belkin na ₱1.4k
    I've been using Tronsmart as well. I can't really complain. I also was able to buy a cable that was 3m long. :-D
    Sent from my Android using Tsikot Forums mobile app
    Apr 2012
    Been using tronsmart charger 3.0 quickcharge. May libreng cable pa[emoji16]
    Sent from my SM-J730G using Tapatalk
    Feb 2014
    i use whatever cable is lying around. believe me i got TONS of them. what's more important is the power source so i just got these very good Ktec 2-amp wall warts. i'll place them around the house
    btw that little gizmo is USB volt/ammeter
    Oct 2009
    PM mo ako bentahan kita ng orig usb cable galing mismo sa package box na samsung ..dami tayo stock nyan.
    Tronsmart is pretty durable
    Sent from my SM-G930F using Tsikot Forums mobile app
    Yung tronsmart after 3 to 4 months hindi na fast charging capable. Bought a pack of 6, same issue.
USB cables
