Results 1 to 10 of 12
- Feb 2008
- 903
August 10th, 2016 10:41 PM #1Should I turn off the APC UPS every time I turn off my PC? I have read somewhere that UPS should always be ON...
- Aug 2012
- 2,767
August 10th, 2016 10:59 PM #2UPS has rechargeable battery inside. If you want to keep the battery fully charged, leave the UPS on.
Sent from my D5833 using Tapatalk
August 10th, 2016 11:15 PM #3
- Feb 2008
- 903
August 11th, 2016 09:14 AM #4
- 54,289
August 11th, 2016 09:19 AM #5don't UPSs have a built-in AVR?
i mean, their output is a regulated voltage, right?
- Aug 2012
- 2,767
August 11th, 2016 09:26 AM #6
August 11th, 2016 09:26 AM #8
So whether leaving it on or off has no effect on the power pack lifespan? I have this habit of turning it off for the weekend or long holiday.
- Aug 2012
- 2,767
August 11th, 2016 09:27 AM #9Types of UPS:
(1) Offline/Standby - No voltage regulation. AC power is directly passed to PC. There are set points for large over voltage at under voltage situations. If voltage exceeds the set points, internal battery will be used for power. This is the cheapest UPS. Price is around P2,000.
(2) Line-Interactive - Has multi-tap variable voltage transformer inside that serves as semi-voltage regulator. (Note: The toroidal transformer inside a servo-type AVR is more precise and better than this.) There are set set points for large over voltage ang under voltage situations. If voltage exceeds the set points, internal battery will be used for power. More expensive than Offline/Standby UPS.
(3) Double-conversion/Online - Internal battery is used all the time so output voltage and frequency is much more controlled. Has faster response time during brown outs since battery power is passed to the PC at all times. More expensive than Line-Interactive UPS.
(4) Hybrid Topology/Double Conversion on Demand - Has the highest efficiency. can function as Offline/Standby and Double-conversion/Online depending on the power situations. Most expensive UPS type.
- Jun 2015
- 2,751
August 11th, 2016 10:24 AM #10Turning your UPS off is ok as long as it's been fully charged prior to being turned off.
I haven't used an AVR on my desktop PC since I assembled it. More than 5 years na buhay pa rin ang power supply. Unless you're in an area that has really bad fluctuations, an AVR is unnecessary.
But if you really want to use an AVR then I suppose the connection should be:
Ac outlet - > AVR - > UPS - > computer
Do not use those cheapo, below 500 pesos avrs that come bundled with desktops. They're just glorified extension cords. Find servo type AVRs.
Tapatalked
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
