Results 1 to 3 of 3
    Jan 2003
    Tip 1 : Do u know how to use the edit button (abc or pencil button)?
    Heres how... in the inbox for example; u wanna delete multiple sms, simply hold the edit button, scroll down, and then, press c to delete the marked sms. The edit button can also b used to copy and past text in sms, simply hold it and scroll across, choose copy. pretty good for placing song names in ngages
    Tip 2 : **** happens, on a smartphone, its inevitable u do something wrong, and tis calls for a format of fone. to format the fone, press *#7370#, then enter the lock code, which is the sec code of the fone. NOTE: batt must b full, else if format is disrupted by low batt, consequences will b disatrous
    I heard the code *#7780# works too, pretty much the same i tink.
    for 6600 users, to format the fone, theres an alternative way. Press and hold <3>, <*>, and the buttons, then power on fone, keep holding on the 3 buttons, till u come to a format screen. tis method ONLY works on 6600, and need not enter the sec code. BUT sec code wun be reset to default 12345.
    Tip 3 : TO NGAGE USERS; Did u know u can install .sis files simply using the cable given? Juz plug it in, place the .sis file anywhere on e: (the mmc), not in any folders, root of e:, disconnect, then look for it in manager.
    Tip 4: Save on battery and system memory being used by regulary checking the task manager which can be accessed by holding down the menu button!!
    Tip 5: Type *#06# to display your IMEI serial number, very valuable for the unlocking your phone to other sim cards
    Tip 6: Type *#0000# to view which firmware version you are running
    Tip 4a: Set the screen saver to a short time out period to prolong battery life.
    Tip 4b: Avoid restarting the phone, or repeatedly turning it on and off. This helps increase battery life.
    Tip 8: Don't want to carry a watch and a phone? Set the screen saver to show date and time, then you can ditch the watch.
    Tip 9: Save memory when installing apps, by installing over bluetooth. This can be done using the nokia phone suite and a bluetooth serial connection. Only works with .SIS files, so java still has to be sent to the phone, but will save space when using .SIS files.
    Tip 10: Operator logos
    Use a filemanager like FExplorer or SeleQ to add the folders: "c:/system/Apps/phone/oplogo". Add a .bmp picture to folder "oplogo" and restart your phone! The .bmp picture size needs to be: 97 x 25 pixels
    Tip 11: Check if the recepients phone is on
    Delivery reports
    or
    Type *0# your message in the message composer window space then write your message, the recipient will not see the star zero hash bit - just the message When they read it it will relay a message back to your fone showing the time they recieved it. (haven't yet tried it myself though)
    Tip 13: While you are viewing a picture in your phone's gallery, press one of these shortcut keys (definitely works on 6600, not sure about other symbians)
    1 - turn image anticlockwise
    3 - turn image clockwise
    * - toggle on/off of full screen
    5 - zoom in
    0 - zoom out
    #15 u can select all files in a folder by selecting THE folder and copy it then paste it somewhere. however u need to make a new directory. fexplorer wun let u copy that folder together. well seleQ can mark files to copy but it really takes time!
    #16: A soft and Hard reset
    A Soft-reset - the process of resetting all the settings of the phone to the factory default! No applications are deleted! A Hard-reset is like formatting a drive! It does format the memory. Everything that has been installed after the first use of the phone is deleted! It will recover the memory of the phone to the state you purchased it! It is done by inputing the following code: *#7370# NOTE: The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable.
    #17: Formats of images
    supported ones: JPG UPF GIF87a/89a WBMB MBM TIFF/F PNG EXIF
    Press and hold the Menu key to open the application switching window, where you can *duh* switch between applications.
    If a program hangs and you can't shut it down, select the application in the
    application switching window and press 'C' to kill it. It's also a faster way to exit programs.
    Turn on/off the "click" sound made by the camera by selecting the 'Silent' profile or by turning warning tones on/off:
    Menu > Profiles > "select your activated profile" > Personalise > Warning tones > On/Off.
    (This also effects the sound of Java games and apps).
    To change background image go to:
    Menu > Tools > Settings > Phone > Standby mode > Background image > Yes > "choose an image".
    The best size for background images is 174x132 pixels.
    Only got blue, green and purple in your 3650 colour palette?
    This free app adds 3 more colours: Palette Extender.
    Display an image when someone's calling:
    Menu > Contacts > "select a contact card" > Options > Edit > Options > Add thumbnail > "choose an image".
    Add a personal ringing tone to a contact:
    Menu > Contacts > "select a contact card" > Options > Open > Options > Ringing tone > "choose a ringing tone".
    Delete all messages from your Inbox at once:
    Menu > Messaging > Inbox > Options > Mark/Unmark > Mark all > Options > Delete.
    Send or hide your caller ID: Go to: Menu > Tools > Settings > Call > Send My
    Caller ID > 'Yes', 'No' or 'Set By Network' to follow the default settings of your home network.
    If you often copy large files to your MultiMedia Card, I recommend a card reader.
    E.g. With a card reader it takes only 12 seconds to copy a 10 MB file!
    Record the sound of a phone call using the (sound) Recorder.
    Menu > Extra's > Recorder > Options > Record sound clip.
    Note: short beeps are audible during call registration.
    But there is a 60 second limitation so if you want unlimited sound recording get this app: Extended Recorder.
    While writing text, press "#" to switch between upper and lower case and Dictonary on/off (predictive text input).
    Press and hold "#" to switch between Alpha mode and Number mode.
    Keyboard shortcuts for zooming and rotating images in Images:
    1 = zoom in, 0 = zoom out, press and hold to return to the normal view.
    2 = rotate anticlockwise, 9 = rotate clockwise, * = full screen.
    In standby mode, press and hold the right soft key to activate voice dialling.
    To add a voice tag to a phone number, open a contact card and scroll to the phone number and select:
    Options > Add voice tag.
    You can customize both soft keys located below the screen (in standby mode):
    Menu > Tools > Settings > Phone > Standby mode > Left/Right selection key > "select an application".
    In standby mode. press scroll key center (joystick) to go directly to Contacts.
    In standby mode, press and hold 0 to launch your wap home page.
    In Menu or any subfolder, press numbers 1 - 9 to start the application at that location.
    123
    456
    789
    In standby mode,
    45# + dials the number on your sim in memory slot 45.
    50# + dials slot 50 and so on.
    If you have your keylock activated just press the on/off button to turn on your backlight
    to look at the time when it's dark without having to unlock the keypad.
    Why assigning Video Recorder in the right or left soft key does not work?
    (Sound Recorder is launched instead of Video Recorder)
    It's a bug with firmware version 2.50.
    Start up in Safe Mode so no 'auto start' apps will be running:
    To make sure that no memory-resident programs start when you reboot your phone,
    hold down the pencil key when you turn on the phone and hold it on untill you have to enter your PIN code.
    (When you have trouble booting up the phone with the MMC in it because it got corrupted for some reason, this trick will
    almost always let you boot up the phone so you can remove the latest installed app which might have caused the
    problem or if your phone is "unrepairable" you can still back up your important data before you do a format.)
    To reset your wallet, should you forget your code,
    Type in:
    *#7370925538#
    this will reset the wallet code, the wallet contents will be deleted.
    Jan 2003
    How to free more RAM on your phone >>>
    >>> Method 1: Flight mode:
    Put your phone in "Flight mode" with Psiloc System Tools. Install System Tools, open it and select "Flight mode". This way you can restart the phone without your SIM card so there will be no running phone tasks in the background. Now you can have up to 3,5 MB of free RAM!
    Note: ironically enough, Flight mode doesn't work when Smart Launcher is installed, at least in my case.
    But i've also heard several reports of people who have both apps running without any problems.
    >>> Method 2: Smart Launcher trick:
    Install Smart Launcher and open it. Go to Options, Settings and put Launcher ON.
    Now plug in your charger and switch off your phone. Wait untill the battery meter appears and short press the Menu button (don't hold).
    The menu should appear and now you can have 3,5 to 4,5 MB free RAM! (Hold Menu button to check RAM).
    The trick is that with the charger plugged in, the phone must get a minimum software support for charging, even when
    the phone is switched off. And somehow Smart Launcher has still got it's shortcut running and that's the Menu button. So when
    you press the Menu button, you go directly to the Menu without any other phone tasks running in the background so
    you trick the phone and you have more free RAM!
    Note: when you unplug the charger, the phone will switch off.
    >>> Method 3: Menu :
    This method I found it by myself, it frees a little about 100~200 KB but I guess it's useful sometime
    Close your menu not by selecting the right selection key "exit", or pressing the menu key another time, they only hide the menu app but do not close it, to close it select the left selection key "option" and scroll down and select "exit"
    So when you open an app needs more ram reopen menu and close it, it's useful when play low bit rate video in realplayer paradis.
    Oct 2003
    Pwede ba lahat iyan sa Nokia 3210? :D Hehehe
Tricks And Tips para sa Nokia Phone nyo
