Results 1 to 9 of 9
May 8th, 2014 09:34 PM #1
anybody can help me here on how to transfer phonebook contacts from my old iphone3gs to android phone? i cant just do it manually since my phonebook have more than 1,000 entries. i tried surfing the net and all of those apps are not free. anybody knows a free app for this? tia.
- Jul 2013
- 2,450
May 8th, 2014 10:12 PM #2Google is your friend my friend
http://m.digitaltrends.com/mobile/ho...e-and-android/
I personally use gmail to store my contacts so i can sync it to multiple devices.
Sent from my GT-N5100 using Tapatalk 2
May 8th, 2014 10:30 PM #3
the problem sir is that my old phone is iphone 3gs. most apps requires the latest iOS software. i tried the route you suggested sir lew but it wouldnt just work out. is there a way to upgrade the OS so that i can download the required app? nakakainis talaga, palagi kong dala ang luma kong phone, ayaw din mag save sa sim pala ang iphone.
May 9th, 2014 12:20 AM #4
May 9th, 2014 12:28 AM #5
What brand? If it is an lg or samsung, its easy as 1, 2, 3
Posted via Tsikot Mobile App
May 9th, 2014 12:32 AM #6
Worst case: manually add all contacts to your gmail account. One time big time lang naman. Should also help you get rid of old unused numbers.
May 9th, 2014 02:20 AM #7
Try to export the contacts then you will have a vcg file. Email to your self, access through android, then it will populate automatically.
Another thing, if you are sync with itunes, sync your contact to outlook (be carefull, configure it one way to pc only).
Then sync your android and sync with outlook (to android only).
That shoild be easily doable.
Other phones, like samsung can pick up directly sync data on any iphone using kies.
tried it with LG, not sure with other brands but I think it is the same across all brands.
May 9th, 2014 07:37 PM #8
my new phone is samsung note 3. i will try your suggestions sirs. the problem i encountered is that the OS of iphone 3gs cant export files to gmail, only iphones with later OS will work. nevertheless, kung wala talagang pag asa, manual upload ko nalang talaga. thanks sir brainmafia, hope it will work out.
May 12th, 2014 12:15 PM #9
another way is sync your contacts to outlook via itunes.
then outlook to google via google sync
then sync your phone ota via google.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
