I use u*******. Parang mas mabilis ang download ng Bleach eh. Hehe.
Right now, I'm on Vista RC1. It can't get anymore resource-hungry. I have 2 simultaneous downloads: one with Limewire, the other with u*******. AVG is also doing a simultaneous deep scan of the pc. Paintshop Pro is also open in addition to this browser.
Yet no slowdowns like you had. My Task Manager:
I'd say what problems you had was unique to your pc.
Add: Once AVG got done with its scan, cpu usage dropped to 1-4% with the d/l continuing.
ako azures kaya lang pag pinagsabay mo sila ng limewire patay na tapos ang baba pa ng ratio ko .19 lang di kasi ako nagdodownload ng movies puro games lang tsaka FHM. 2gig download pero upload ko 250mb lang hay paano ba paupload ng mabilis.![]()
Set your upload speed to at least 80% of your download speed and upload as long as needed.
:fly:
Edit private tracker ratio 3 for 1
public ratio 2.8 for 1
Edit2 anyone with invites for oink pm mewill not disappoint.
Last edited by GasJunkie; December 19th, 2006 at 06:39 PM. Reason: carp, should have been 80%
I forgot to mention that I also have Windows Defender running in the background in realtime mode. So, I don't know. I've had Limewire running 4-5 simultaneous downloads (mostly **** stuff), several 100+ mb podcast *******s though ********/u*******, plus Wndows Defender or AVG doing their thing, Ad Aware and Spybot: Search and Destroy scanning in tandem plus surfing here, watching Star Trek Divx and dvd movies.........This computer barely shows any dragging performance under XP Home.....
Maybe having the page file permanent at a separate hard drive from XP have a lot to do with it.
AMD X2 4200+ (non-overclocked)
MSI K8N Neo4 Platinum
2 x 1GB Corsair DDR-400
ASUS 256mb pci-e X800XL ViVo, dual DVI
Antec Truepower 2 480 PSU
Pioneer DV-109 16x DL DVD burner on secondary IDE channel
SB Audigy 2 Value
Logitech Z-2300 2.1 speakers
MS wireless keyboard/optical mouse
200GB IDE HDD master on primary IDE channel - XP Home
250GB IDE HDD slave on primary IDE channel - permanent 2GB page file
120GB Crossfire FW external hard drive
60GB 2.5" homebuilt usb2 external hard drive (powered via usb port)
Aspire Silver X-Cruiser case with a few additional fans......
Pic:
http://www.gadgets.ph/gizmos/data/2/My_Den.jpg
http://www.gadgets.ph/gizmos/data/50...uiser_dark.jpg
Oh yeah. Vista RC1 is on a 40GB Maxtor HDD slaved to the secondary IDE channel and dualbooting with XP Home
OT#1: No wonder! Your system is on the high-end side. I'm sure , it can handle just about anything you throw at it.
OT#2
I recently replaced my P4 3.0 E Ghz "presshot" to a AMD 64 3200+, after its motherboard conked out and the stores here ran out of socket 478 MBs. One thing, I noticed about my AMD is that it does not like multi-tasking (even with 2GB of Corsair DDR 400). Also when I play DiVx video clips, sometimes there is a slight pause (cpu usage spikes). This is something I dont see in my old 3.0E ghz P4. Funny.
I haven't kept up on cpu specs. But, didn't the P4 3.0E have heperthreading? That helped a lot. The P4 has always been strong when it came to multimedia stuff. AMD Athlon64's were better in gaming. But, the difference in framerates was more than made up for by the type of video card.
I assembled my pc back in July of 2005 when the AMD dualcores were the top cpu's. It's been almost a year and half and I'm still very happy with my pc.
Again, a lot of what makes XP happy, in my opinion, is having the page file at a separate hard drive from the OS. It also just happens that the 250GB hard drive with the pagefile is the fastest drive in my pc.
Changed ******* engine from bit******* to u*******. Sobrang laki ng improvement no errors, no stalls smooth downloads masmabilis pa. Now I need a bigger hard drive.
I usually upload 2 to 3 movies (dvd) a month that's why my ratio so high(used to be 8 to 1)
:fly:
Edit have you seen the ratio of some public trackers (seeders to leechers) ridiculous..
How high do you let your share ratio get before you stop seeding? I usually stop seeding when my share ratio reaches 2 is this ok?
hey... i'm using ******* right now although i also tried bittorent (same results). i have a 756KBps dsl connection. first time ko to deal with ******* files...
average DL speed ko is about 10-15KBps lang even if i'm not running any other programs. i'm not sure about my pc's specs, but i'm sure that it can keep up pretty well even if most of the programs are running at the same time. is it the software (*******) and is there something that i can do about it? thanks!
last time i checked, 9(18) seeds, 39(93) peers. what do seeds and peers mean? i got the ******* file from ************ - does the site where i get the ******* file also affect the downloading or are they all the same regardless of where i got the file? if it does, which site/s do you recommend?
Peers are participants who don't have the complete file, like you. Seeders do.
I'm not sure what the number in () means, I use a different BT client. Try poking around in your client's options/settings, on download and upload rates maybe. Sorry, can't tell you what to look for, I'm not familiar with the program you're using. Hopefully, others are.
It shouldn't matter where you got the *.bit******* file if it's the same file and points to the same tracker. How large is the file? How far along is your download? Generally, BT downloads start slow, then progressively get faster, then tapers off again bago matapos.
