Results 1 to 10 of 32
April 6th, 2006 11:59 PM #1
mga mahusay sa pc hardware tulong naman. ung ports ko ayaw gumana. pag bagong bukas ung pc ayos galing sa matagal na pahinga ok siya, gumagana at nakakapag print ako. pero after ilang minutes ayaw na. kahit restart ko ayaw pa rin. nagkakaroon ng ! don sa device manager. ung floppy, saka ports ung nagkakaron ng !. kaya tuloy hindi ako makapagprint. nilinis ko na ganon pa rin.
tulong naman kung pano ayusin to. salamat!
- Feb 2005
- 130
April 7th, 2006 01:35 AM #3
try to open device manager and uninstall the ports from there.
turn the computer off.
when you restart, go to the BIOS, and follow the steps there to reset BIOS settings and savce changes.
let windows go back up, redetect the ports, and hope this helps.
April 7th, 2006 01:48 AM #6
*cozee, no problem with the drivers, pati nga reformat ginawa ko na. hehehe.
*nugundam, ok thanks. subukan ko na ngayon. will update you soon.
Tsikot Member Rank 4
- 2,716
April 7th, 2006 01:56 AM #7baka sakaling makatulong ... palitan ang CMOS battery or at least clean its contacts if you are sure battery is still ok
April 7th, 2006 02:03 AM #8
*nugundam, sinubukan ko na ung sabi mo pero wala pa rin nangyari. hehehe. eto nga pala ung mga nakasulat sa status
lpt1:
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
com3 and com4:
This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device.
*kinyo, sige subukan ko din yan.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
