Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    One of my WD Passports suddenly can't be recognized by my PC or my media players. There's around 1.5TB of HD movies inside.
    Nothing happens when I plug it to my PC. Sometimes, it will appear in the file explorer (if it was unplugged for a few hours), then after a few seconds, it will just disappear again. Not enough time to even perform a check disk.
    How can I still recover the files stored inside? I read that the hdisk used is different from the regular drives since it is USB powered, so I can't just remove the disk and put it inside my PC.
    Signature
    Jan 2009
    What's the model? Have you tried a different USB cable?
    Sep 2012
    Sir Items to check muna and assuming you are using the samll one 2.5 " size and its already out of warranty
    1) Try replacing the cable first yung sa USB... kung yan yung micro USB ang dulo pwede dyan gamitin yung cable din na pang Android phone like HTC etc
    2) If it gets detected na, as a good practice para hindi sya create ng create ng USB profile, just plug it on the same port anytime na gagamitin mo.
    3) If ever na islolate na na hindi yan cable problem talaga, last option is to get the hard disk inside... standard na SATA or PATA drive naman ang laman nyan ingat lang sa pag pry open then you can buy a replacement HDD enclosure sa CDR king
    What I know is the HDD used for USB drives are the same as laptop HDD. So you can just open up the USB HDD case and install the HDD into your PC.
    Oct 2011
    Ganyan talaga sakit ng mga external portable HDD. Try mo muna checkdisk to see if it can be fix, if corrupted na talaga then run Photorec to recover your file. HTH.
    PhotoRec - CGSecurity
    I forgot the exact model name. Ang nakalagay lang sa casing is WD My Passport. 2TB capacity.
    I already tried to swap the cable with my other Passport, ganun pa rin. USB 3.0 yung cable.
    Signature
    From what I read in the web, the WD Passport have write encryption chip plugged to the hdisk, so even if I can remove the hdisk, baka I can't retrieve the data na rin?
    Signature
    Sep 2005
    have you tried it sa ibang pc or laptop??
    Yes, ganun din. Madetect sandali, tapos mawawala after a few seconds.
    Signature
    Sep 2005
    usb powered ba yan? or may sariling power supply.. had the same problem just a few days ago.. kaya lang maxtor naman to.. nahugot bigla yung power.. na corrupt yung hard disk.. eh backup pa naman nang mga pics from way back 2003.. 600GB yung nawala.. ayun I used photorec.. na recover naman halos lahat.. kaya lang halo halo and it created around 3000 directories.. ang dami pang ibang files.. txt files, db files, etc.. halos 2 days tumatakbo..
    try mo muna scandisk..
    Feb 2010
    Anong operating software ang gamit mo sir? Windows? Try mo sa ibang pc na may linux operating software baka maopen mo siya.
    USB powered. Hindi naman sya nahugot, lagi lang nakasaksak sa media player. Then one time bigla nalang ayaw lumabas yung drive sa media player.
    Kapag naa-access naman, kita ko pa naman yung mga directories. Pero ilan seconds lang, mawawala na yung drive.
    Signature
    Quote Originally Posted by asb75 View Post
    Windows 7. Gusto ko nga i-try sa mac pag makapasyal ako sa friend kong may mac.
    Signature
    Jul 2012
    Happened to my WD external hard drive before. Replaced the cable, ayaw pa rin. So binuksan ko, tried placing it sa laptop ko mismo and nag-appear naman sa BIOS. Finally changed its enclosure to this one, problem solved. I think Php180.00 lang bili ko nito sa mall (PC hub or PC corner cant quite remember) 6 mos. ago.
    Quote Originally Posted by deafault View Post
    Will try first with an enclosure from cdrking. I don't have a laptop anymore.
    Signature
    Jan 2004
    Nangyari na sa akin yan. Binaklas ko na kasi SATA lang sa loob. Irerekta ko sana sa PC pero wala naman akong desktop. Pinadala ko na lang sa Pinas baka magamit pa.
    Sep 2012
    Correction on my initial post with regards to interchanging it to a new case if yung model na hawak mo is merong encryption chip. Meron din ako ganyan na WD pero bihira ko gamitin kasi hindi ko pa ma research yung pang break sa hardware chip kung pwede. Sticking to TrueCrypt for all others drive kasi
    May thread similar to your case sa WD forums
    Has anyone successfully recovered data from a WD 7... - WD Community
    I disassembled the enclosure. It's actually just a casing. There's no other electronic parts separate from the harddisk itself. So the problem is really with the hdisk.
    I was able to transfer a few gb of data today. Then it disappeared again from the file explorer.
    Signature
    Another thing I noticed with the hdisk, when I insert the USB cable to the PC and the hdisk light blinks, it is being recognized by the computer. If the light just stay lit, and no blinking, then it is not seen by the computer.
    Signature
    Jun 2011
    o.t. lang po...
    bro. boybi... may nakita ako sa sulit 1 tera- toshiba 3,250 lang.... good buy na ba yun? nabagsak kasi nung office mate ni wifey HD ko nasira....
WD My Passport external hdisk can't be detected
