Nah, I just shared the pros, cons & measures needed. We even specify a minimum of 1.25" PPR drain, not blue. Splits are ideally installed along perimeter walls, where possible, to avoid lines running thru ceilings. If unavoidable, the insulated lines must be laid on gutter trays or thru pipes...I can go on & on.
Though I find joy in those of others, leak therapy isn't fun. Leaks can leave indelible scars, literally & figuratively.[emoji17]
Please don't get me wrong...I'm not anti-anything here. Just sharing to help prevent splitphobia.
They both have pros and cons. For me, split type is for aesthetics. It's just weird that before my split type would leak every six months while I never had a problem with window type even if I don't have it cleaned for years. What I don't like about window type is the hole in the wall (which is minor).
Parang sinasabi niyo mag-Vios nalang lahat ng tao kasi pag high end na kotse na maraming features mas maraming pwedeng masira.
Well ako ok lang yung tradeoff na yun basta ayoko ng panget at maingay. [emoji23]
Was planning on having holes for window type a/c punched through the walls prior to the turnover of our house but, alas, we lacked the funds to purchase a/c units then (actually, ngayon na 5 months after wala pa ring funds) para makuha yung dapat na sukat. Now, split na lang ang pipiliin ko talaga dahil laking hassle na kung magpapabutas pa nang malaki sa pader.
Pag split-type ba butas lang ba para sa tubes ang gagawin? Papano wirings? May wall sockets na kasi sa walls for a/c. Magagamit ba yun?
Sent from my ASUS_T00J using Tapatalk
nagpabutas kami dati ng aircon rectangulo. no problem. no issues. no regrets.
...as long as there is no compromise in structural strength.
years later, we replaced the old aircon with a smaller, newer one. we could have spent more, but... pinasakan na lang namin ng kahoy yung butas, at pina-beautify yung paligid.
it's part of the professional way of thinking, what with having to deal with all sorts of patients' pocketbooks.
also, it's dad's way... "mahal yan! heto na lang.. mas mura na, mas matibay pa. huwag nyo lang i-sali sa beauty contest".
(yes, that's where i got one of my favorite quotes.)
but thank you.
So to summarize:
Window type:
Pros: Simple to install and maintain
Cons: Panget itsura, maingay, limited inverter choices
Split type:
Pros: Looks clean and unobtrusive, higher EER vs window (even inverter window), quieter
Cons: Maselan maintenance and kailangan maingat installation
Between the two, yung cons ng split type pwedeng mamitigate if you install properly a d get a reputable brand. Travs already shared very helpful advice on how to mitigate the cons of a split type (thanks a lot bro!). Yung cons ng window type yun na talaga yun wala ka na magagawa.
To each his own, but after weighing all the factors, split type preference ko.
Some splits require the power source outside by the condensing unit, some by the interior unit. Consult your supplier/tech on the chosen brand/model's requirement. It's ideal to install on perimeter walls (as you would a window) & try not to embed lines. The drawback? It's not gonna be pretty outside as it will be inside. The shorter the line route, the more efficient.
On conrete wall boring for Window units, it's a simple cut & chip. An hour or 2's work. To prevent wall repainting, precision measurements, alignment & edge cutting are needed inside & out. It's possible to chip thru a clean rectangle. The vertical dimension of the hole should be about 15mm over the Window AC's vertical side measurement to allow for sloped install.
Anytime, good sir. Enjoy your new ACs.
I just got my split type aircon installed a 2 months ago and it was cool and economical. My electric bill was only 1k. I didn't use it that much since it is december. An accumulated 72 hours is my estimated use before billing. It was an LG Dual Inverter Type. Check this video link if you wanna see it Split Type Aircon Installation LG Dual Inverter - YouTube![]()
Trying to decide between LG and Daikin. Naka IOT na kasi ang LG washer/dryer namin and the app notifies me kung tapos na ang cycle. This is helpful dahil nasa roof deck ang machine. Is the Daikin app helpful? At least if I get another LG kasi I only need one app to monitor several appliances but most of the folks here recommend Daikin.
