Page 101 of 169 FirstFirst ... 5191979899100101102103104105111151 ... LastLast
Results 1,001 to 1,010 of 1687
    Is there a gadget for measuring a specific appliance's electric consumption? I hope it's cheap if there is, I like to buy one.
    seach: kill a watt
    Jan 2016
    #1002
    thanks, watt meter pala tawag dun, dami sa lazada for 1k
    #1003
    most appliances indicate the gadget's wattage consumption (220V 3.0A, or something like that) in the manual or on a paper, plastic or metal sticker on the appliance itself.
    Jan 2009
    #1004
    Particularly for wattage and amperage, those are usually the stated maximum that the appliance will ever require. They're meant to help contractors and electricians design the proper circuit for it (correct-rated wires, switches, plugs, and breakers).
    A watt-meter or power meter is still necessary if you need to gather realtime power consumption. As stated above, there's tons of them on Lazada.
    DO NOT use it to measure the output of a non-sine wave UPS. My old one popped, sizzled, and died after just a couple of minutes while measuring the output from a cheap UPS.
    #1005
    how does one know, which is safe to use, and which is not?
    Aug 2018
    #1006
    Condura split type 1.5 hp. Biglang tumulo.. ano kaya solution?
    Quote Originally Posted by Phayazho View Post
    cleaning the evaporator and filter..
    Aug 2018
    #1008
    Sir, thank you for the info. Pero kakalinis lang po nito, pero hndi ako sure kung pati yung evaporator niya. Filter ok naman malinis po.
    #1009
    Kung kakalinis lang baka hinde napasok mabuti yun Drain pan doon sa Drain hose.
    Aug 2018
    #1010
    Ipapackeck ko din. Baka naiisip ko na baka lang masiran yung aircon. Salamat po.
    Sent from my D6503 using Tapatalk
Split Type Aircon: Which is best?
