Results 1 to 13 of 13
    My camera takes really dark photos. I noticed this recently. I thought it was only because the place was not well lit. Last night we were taking pictures in a well lit area and it still appeared as though we were somewhere dark! I asked my friend to take the exact photos and upon comparison theirs appear the same and normal while mine was dark! I reset the camera settings to default but that did not fix it. I tried no flash, with flash and auto flash but it did not make any difference.
    What could be wrong?
    May 2011
    Err tried adjusting the screen brightness?
    Posted via Tsikot Mobile App
    Increase the ISO settings to 400-600...
    Thanks. I will try that. What is ISO?
    I am just wondering what happened to the camera in my phone? I never tinkered with the settings and now I am getting dark pictures.
    Jan 2013
    Many cameras including phone cameras usually have an exposure compensation setting. Check if your setting is dead spot on the center scale and not on the negative/minus side. If it's on the minus side, all your photos will be underexposed therefore, dark generally.
    Quote Originally Posted by remzam View Post
    Where do I check this exposure setting?
    Quote Originally Posted by car_bore View Post
    It's not my screen that's the problem. It's really the pictures.
    In the picture below, notice that the background is dark. This place is very well lit (daylight lighting) but the pic looks as if we were some place with dim lighting.
    I was just taking different shots and this one looked decent but still a little dark:
    Hmm... Try looking for the settings in the camera menu. Either try adjusting the ISO or turn on the smart stabilization. Not sure though cuz I'm using a note 3...:\
    Jul 2011
    Nung bago pa phone ko pangit din pictures, later found out na meron pa plastic na naka cover sa lens ng camera, ng tangalin ko hapi na ako sa quality.
    Jan 2012
    Try using HDR mode, it makes pics more vivid but usually just makes them brighter
    You might be focusing too near as well
    Dec 2009
    In low lighting condition switch to "night mode"
    Electronic sensors are less sensitive than a human eye..what seems to be bright in the naked eye is not necessarily the same with the electronic eye
NOTE 2 Camera Problem: Dark Pictures
