Results 1 to 13 of 13
    Meron ba ginagamit sa inyo? Para automatic mag on and off siya certain time at the same time pwede ko remotely I cycle pag meron problema?
    Jan 2009
    Smart plugs, as in the WiFi kind?
    You'll be locked out.
    They're typically connected to cloud services (such as Wemo, Tuya/SmartLife, Broadlink, etc.). Once you turn it off, your router goes down and so will your internet connection. You won't be able to turn it back on remotely. Someone will have to physically turn on the switch to restore everything.
    Alternatives would be RF plugs and timer plugs.
    For RF plugs, you'll still need to be in the vicinity and range of the device's RF coverage. A timer plug can automatically reboot your modem/router at a preset time of the day. But use the digital one. Digital timer plugs can go down to 1 minute of on or off time. Mechanical ones have a resolution of 15 minutes, if I'm not mistaken.
    Ok. Thanks guess I'll have to use digital timer plug.
    Jun 2015
    I have this working but in my case I have 3rd party WiFi router connected to the ISP modem/router. The smart plug connects to the 3rd party router but controls the smart plug of the ISP's modem/router. My smart plug is the unbranded kind that goes for less than 300 pesos on Shopee.
    I also think this will work even with just your modem/router provided that you have a pre-programmed sequence of tasks on your smart app to turn off, delay by x time, then turn the plug back on.
    The sequence will be saved on the plug itself so it wouldn't matter if you lose Internet connection when the modem goes offline for a while.
    pwede kaya sa sonoff yan bro?
    di ko pa masyado nakakalikot itong sonoff, aside from kwh consumption logging
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    Jun 2015
    Smart Life ba ang gamit mong app? Sa bottom part ng UI ng Smart Life may "Smart" na icon sa gitna. Duon may options na Automation at Tap-to-Run. Pwede mo duon gawan ng scheduled tasks.
    This is what I do too. I use tplinks Tapo smart plug. I programmed it to turn off everyday at 5am and turn on at 5:01. Ginagamit ko sya sa Globe kasi bumabagal globe ko at bumibilis after reboot.
    Pero kung sa app ko manual na off, kailangan ko puntahan yung plug para manual na ma on.
    Jul 2013
    When my daughter was younger (grade school).
    I used an "old school" timer... House Wi-Fi will turn-off at 11pm and turn on again around 6am.
    This is to prevent her from using her devices all night
    ewelink lang bro
    Jun 2015
    Sa akin instead of a schedule, I created a sort of macro na triggered manually. Ang mangyayari mamamatay ang plug, wait for 10 minutes, tapos mag-ON ulit ang plug. The 10-minute delay is just to make sure na totally powered off na (wala nang residual charge) ang components ng router at para ibang IP na ang makuha.
    At random times kasi nagloloko ang Converge namin kaya hindi pwedeng by schedule lang ang trigger.
    Jun 2015
    Isa rin sa mga want-to-buys ko yan dati. Pero blocking by IP address on a schedule naman ginagawa ko dati. Then on school nights filtered ang internet access by keywords.
    Ngayon, wala nang changes sa router. Google Family Link na lang to limit gadget time.
    Feb 2005
    may nabili ako sa Shopee "Tenda" brand meron syang schedule for reset, ginawa kong 5:00 am everyday...
Smart plug for router/modem
