Results 1 to 20 of 30
    I'm using a smart bro P999 and a Lynksys router, now my problem is I think Smart is now blocking mg router? it started when nilabas nila yun Smart bro router nila, I can't browse the internet kung kinabit ko yun modem sa router but kung i direct koyun modem sa PC eh ok naman....
    saw a link at tipidpc na ganun din ang problem nila...ginawa ko na rin na manually input yun MAC address ko sarouter, first naging ok then bumabalik ang problem...is there any work work around sa problem ko?
    http://www.tipidpc.com/viewtopic.php?tid=176876
    Jan 2009
    i've been using a router the past 3 years and no problem so far. try resetting the router first then configure it again.
    Apr 2008
    Quote Originally Posted by moejun2 View Post
    After reset try to run configuration wizard of the router if meron para straight forward lang. Ganito lang ginawa ko nung bumili ako sa CD-R king ng wireless router gumana naman.
    Aug 2005
    Using same connection and router, wala naman akong problem kahit na ngayong umuulan. Try disabling your connection, unplug your modem power adaptor and router. Wait for a few secs then re-plug them. This time, reset your router. Configure your router's wireless security settings, leaving any MAC configs as it is for the time being, let's see what you get.
    Aug 2006
    Quote Originally Posted by leinahtan View Post
    I'm using Edimax router, okay naman. Minsan nawawala pero dahil sa repeater site problem.
    Sep 2005
    MODEM? di ba po antenna ang smartbro?
    try this sir.
    -write down your PC ip add and DNS servers with your PC connected directly to your
    smartbro.
    -connect you smartbro antenna to your router on internet port and PC to LAN port.
    -plug-in your antenna then after few seconds turn on your router then your PC.
    -open your browser and on the address field type 192.168.2.1(default IP add for any router).
    -router settings and configuration will open/display on your browser...DHCP should be enabled.
    -check your router WAN IP add and DNS servers, it should be the same as your PC ip add and DNS
    servers when connected directly to smartbro.
    -router DHCP will assign 192.168.2.2 on your PC and DNS servers should be the same as your
    router DNS servers.
    -if all IP add and DNS servers assignment are ok...open any website on your browser.
    -you browser will be rerouted to SMARTBRO PORTAL(because your PC and router has a diff MAC
    add).
    -provide all the info needed on the fields for account verification.
    -after that it will display your account status...."account active"(correct me if im wrong).
    -then you can now start browsing the net.
    guys, if im wrong on some part please correct me na lang...TY
    Sw!t!k talaga itong Smart!....
    7909:taunt:
    possible ba na ma block ng ISP ang router ko? how?
    Dec 2007
    Obliging... Kuya Ruel, [SIZE=5]no offense intended.[/SIZE] (pasensya na sa highlighting, I just want to INFORM some people who mistakenly say "no pun intended" instead. )
    Quote Originally Posted by ruelsdcz View Post
    That is not the DEFAULT IP Address for *ANY* router. In fact, I have yet to encounter any router nor server that uses that as the default IP address. Most of them use 192.168.1.1. I've seen some that use 192.168.0.1, but not ...2.1.
    To make this GENERIC, the router's DHCP will then assign an IP address to your PC that has the same first 3 numbers, and a different 4th number.
    e.g., router uses 192.168.1.1 will assign your PC 192.168.1.x, x being dependent on the router's default config. My Linksys router uses 192.168.1.150 as the first DHCP-assigned IP addres. YMMV.
    I think Smartbro is blocking my router!!!!
    ginawa ko na lahat yan, I thought sira na ang router ko but I tried it sa PLDT DSL, in fact I'm using while typing this wala naman problema sa router...
    meron bang way para magamit ko ulit yun router?
    walang problema yun connection eh if I plug yun smartbro directly sa PC no problem at all, but kung idaan ko sa router whether wirelessly or yun PC na wired sa router eh hinde na makapag browse, intermittent connection...
    HELP!!!!
    Aug 2003
    have you tried testing other routers with your SmartBro connection?
    nope, not yet, but I tried my router with other ISP and it's working fine.
    possible ba na i block ng Smartbro yun router ko?
    Sep 2005
    Quote Originally Posted by woohoo View Post
    ok lang po sir WOO...ty for the corrections. its only based on my experienced in installing wifi router. cguro nga po im wrong sa post ko. i think about 4 brands na po kci wifi router ang nainstalled ko they all have .2.1 default IP add.
    Jan 2009
    any updates here shadow?
    so far ok na naman, after thousand of calls to their call center, but I'm still observing my connection...
    OT:
    effective pala yun mag complain sa NTC, I fired an email to NTC and explaining that Smart was blocking my router, na forward kaagad nila sa Smart yun complaint ko, then nag email kaagad ang Smart sa akin...
help! router on Smart bro
