Results 1 to 15 of 15
    May 2005
    cant seem to find the post on this.
    i bought a d-link 54g wireless router.
    how do i secure it so that people in my neighborhood can't have access to it.
    tried the instruction on adding WEP code or something, ayaw eh.
    mga techie guru, help naman.
    TIA
    for linksys you can access it via your browser. use 192.168.1.1 then after you've entered the setup password you can enter the setup menu. you can now set wireless security using either wpa or wep or whatever protocol you have. save settings after
    Sep 2005
    Just don't use WEP unless ang mga katabi mo mga oldies.. Gamitin mo WPA/PSK.
    Jan 2003
    WEP is still better than no encryption though. Usually, upgradeable naman ang firmware ng mga wireless routers and cards, so if WPA support is not there, just check the vendor's website for updated drivers.
    one way to secure your network is i manual enter ung mga Internal IP add ng gagamit ng connection ata, or try using a WEP key
    Jun 2006
    You can use MAC Address filtering.
    For the MAC Address, check your wireless adapter's MAC addresses and add it in the router's list of Permitted MAC Addresses.
    Mar 2005
    don't use wep
    use wpa-psk
    Jan 2004
    WPA2 na lang kung puwede, and use AES para walang masyadong slowdown.
    What's wrong with WEP?
    WEP isn't that secure. It's still possible to "sniff" your data.
    How's that possible?
    Sep 2005
    http://docs.lucidinteractive.ca/inde...eless_Networks
    Jun 2007
    my suggestion as ive been using wi-fi,
    No1 - -- the best thing to do to protect your privacy is by not broadcasting your SSID, for that reason you and you alone knows your SSID so youre the only one who can access that SSID as u are the only one knows the name.
    no.2 --- use the most secure code - WPSK i think, theres 4 different kinds of security- it uses hexadecimals.
    no3--- for more security, go to your wireless configurationoptions. theres a part in where you enter MAC address. this way only a certain MAC address will allow the computer/laptop to access router to access internet. to find your MAC address. start-run- from run command-->type "CMD" -->the command prompt will come out--> type "ipconfig /all" all info will come out --->look for "physical address" it will have hexadecimal consisting of 16 digit with"-" spacing. thats what you type in MAC address on your router configuration. this enables your computer to securely connect to the router/internet. it will not allow other to get into your wi-fi connection as it only recognises the recorded MAC address. this will work even though they can "see" your SSID (name of the router - default name "brand name") they cant access your wi-fi as you alone knows the username/pw to access the router configuration. you need to add others MAC address if you want them to connect. MAC address is unique to all computers. same as IP address.
    hope it helps!
    if u cant be bothered with MAC addressing, use no1 and 2. much easier!
    May 2005
    thanks very much mga brods!
securing a wireless router
