Results 1 to 9 of 9
December 17th, 2006 02:52 PM #1
i have a pc with a 40GB HDD capacity without partition. question: posible bang mag add ng partition drive WITHOUT HAVING TO REFORMAT THE pc? What advantages does a partitioned HDD have over the non-partitioned ones?
December 17th, 2006 03:01 PM #2
partition magic software. Haven't used it pero i think it could help.
December 17th, 2006 03:27 PM #3
The only advantage I can think of is that you may want to store drivers in a partition different from that of the operating system. That way, if the OS goes kaput and you have to reformat the OS partition, your drivers will be fine. Just be careful you don't delete the storage partition as well.
Personally, I rather keep drivers in a removable media like a cd, flash drive, or an external hard drive.
Also, if you have the earliest version of XP, like my XP Pro Upgrade cd which dates back to Nov 5 2001, I don't think the install can recognize anything over 40GB yet. You'd have to partition the hard drive or use the included hard drive partitioning utility.
With a 40gb hard drive, I rather not partition it.
December 17th, 2006 04:59 PM #4
+1 for sir jun..
40 GB now is too small para sa mga naglalakihang digital files.. i suggest na bumili ka na lang ng isa pang HDD with bigger capactiy to serve as your back-up files (secondary), madale man ang primary mo, safe pa rin ang mga back-up files mo... or BURN it.....
- Aug 2003
- 9,720
December 17th, 2006 05:33 PM #5you can also use Norton Ghost to clone and resize your active partition -- but you'll need a spare drive for this.
Me nakita din akong Ghost for Linux, a freeware disk cloner. You can download and burn the bootable ISO image onto CDR(it uses linux as base OS, after which you run the 'g4l' program)...pero you'll need a spare drive pa rin
December 17th, 2006 06:54 PM #6
personally, if i have only one 40Gb hard drive, i'd still partition it in two. i always like to keep the OS files seperate from my personal data files.
this way, if reformatting is the only option, i dont need to backup my data to reinstall the OS. this happens very rarely, though. last time i went around 2 years or so without reformatting any hard drive at all.
December 17th, 2006 07:19 PM #7
To answer your question, if you already have a working system with OS installed, Partition Magic can make another partition from your 40 GB HDD without having to reformat it.
The benefits is, you can separate your personal files from the OS files by placing them in different partitions. For example, you can place all your office files (*.doc. *.ppt, *xls. *db, etc...), mp3, pictures, etc.. into the new partition so when your OS needs reformatting you can just format that partition without affecting the other files in your other partition.
December 18th, 2006 05:20 PM #8
ic. btw does this norton partition magic a freeware? and has anyone tried using it?
December 18th, 2006 05:29 PM #9Originally Posted by redlake_56
