Results 1 to 17 of 17
    We have a blower with a 25hp motor attached. Last year nasira yung 25hp motor. Since it was an emergency, and we don't have a 25hp motor on hand, the technician replaced it with a 15hp motor. It operated as usual without noticeable drop in performance. Since then, we haven't replaced the motor.
    Questions:
    1. Could the supplied 25hp motor be too much for our application?
    2. What could go wrong by replacing blower motors to a lower hp ones?
    Is it off the shelf or custom made? Like 12vdc said, it could be that the system was designed with an allowance; otherwise, you could be looking at an overworked motor.
    Quote Originally Posted by Monty View Post
    Yes, that is the Factor of Safety..... and should be true for any system design....
    25.7K:shark:
    The blower is being used to transfer air from one chamber to another.
    Also, I don't know how to call this, but at startup, the motor operates at a lower rpm, and then switches to its normal operating rpm (around 1760rpm) after a while.
    So far, it's been operating normally without any noticeable difference in performance.
    Signature
    This is the typical Typical y - delta connection. It is normal for all motors from 5hp above. Some more complicated is the auto - trans. Hehehehe.
    Normal lang yan bro, kung gusto mo lagyan mo ng vfd, kaso overkill sa mahal para sa 15hp lang na on/off application.
Question for mechanical engineers: Replacing blower motor to a lower rating one
