Results 1 to 13 of 13
    Aug 2003
    how true na hindi na siya kelangang i discharge before recharging? does this mean that it's safe to pop in fully charged NiMh's into a digicam, use it to snap a few photos, then have them recharged immediately(in a nonsmart charger)? according to a saleslady, NiCd lang daw ang kelangan i discharge.
    according to one of the sites i visited, masama din daw kung fully discharged ang NiMh batteries.
    Jan 2003
    sir..
    here is the answer: http://www.zbattery.com/memoryeffect.html
    Mar 2004
    i use 2 sets para pag low na yung isang set yung isa naman gagamitin ko. bale pag fully discharged na yung isang set tsaka ko lang nilalagay sa charger...two sets lasted for 2yrs...laging gamit yung digital camera...
    eh yung Li-Ion battery? yan kasi ang nasa digigam ko ngayon, dati rechargeble AA ako sobrang parusa...hindi maasahan...
    Jul 2006
    advisable sa lahat ng batteries once a month super drain then once a month charge of 6-9 hours.
    Mar 2005
    If you try to recharge a 99% full battery (like when you snap just a few photos) it will be overcharged even if you use a smart charger. Bad for nimh, and to a lesser degree nicd.
    full discharge is also bad if you have several cells in series because the weakest cell will die first and will undergo reversal.
    If yo uwant to recharge better if you drain it a bit more, like down to 80% or so...
    You don't have to fully discharge nimh. For nicd fully discharge about once a month.
    Mar 2005
    Quote Originally Posted by mikmik316 View Post
    Nope.
    AFAIK, NiMH has "done away" with the "memory effect" which is the main sickness of NiCd batteries. LIon batteries has totally done away with the memory effect.
    Mar 2005
    Quote Originally Posted by kimpOy View Post
    li-ion is most convenient, you can charge anytime, you can even leave it in the charger all the time it won't overcharge.
    ni-cd kailangan pang i-discharge para hindi masira. ang daming kong ni-cd na nasira dait kasi hindi na discharge o totally drained. ung ni-mh kahit pwede ng diretso sa charger pag lo-batt na. ung ni-mh ko 5 years na ok na ok pa rin. gamit ko pa nung tamiya days ko. ngayon nasa remote na lang o kaya minsan sa digicam.
    Jun 2005
    As much as possible, I fully drain my NiMH & Li-Ion batteries (cellphone, digicam, laptop) before recharging them. But, if I'm on the go, I recharge them even partly drain pa lang sila. I think it's safe.
    Jan 2003
    Quote Originally Posted by j_avonni View Post
    do not fully drain Li-ion batteries. mas masisira sila pag ganun. yung 6610 li-ion battery ko, 3 years na pero ayos pa rin kahit charge lang ako ng charge. kung mapapansin nyo yung 3210 NiMh battery ay madaling masira kapag ndi mo fully na discharge tas kinargahan mo sobrang dali ng buhay ng battery na yun.
    Mar 2005
    Quote Originally Posted by A121 View Post
    Actually you can't fully drain a li-ion. The phone turns off loooooong before the li-ion is drained. The electronics make it idiot-proof.
question about nimh batteries
