Results 1 to 10 of 11
- Nov 2005
- 81
February 2nd, 2007 04:11 PM #1gandang araw sa lahat,this is my first post on this forum,can somebody help me how to upload games on my PSP?bale nkabili ako ng copy dvd games dko lang alam paano step by step ng pagt-transfer sa console,kylangan pa ba ng card reader nito?what i have here is only the usb cable,sensya na guys noob ako sa mga ganito,need your help,step by step pls....thanks in advance!!
February 2nd, 2007 04:19 PM #2
you dont need a card reader if you don't have, although it will help if you have. what you need is a cable connecting the PSP to your PC. dami nyan sa electronics boutique. once you connect your PSP to your PC, your PC will read your PSP as a removable hard disk as if you are using a flash disk. create the proper folders (PSP only detects games/movies stored in the memory stick if you put it in its proper folders with proper names), and put your stuff in.
if you have a memory card reader/writer, you don't need to connect the PSP directly to the PC. just pull out the memory stick, put it inside the memory card reader/writer and follow the procedures stated above.
for additional information, visit www.pinoypsp.com.
hth.
- Nov 2005
- 81
February 2nd, 2007 04:23 PM #3yeah tnx for the quick reply Gilmore,the problem here is hindi nababasa ng Pc as a removable HD ung PSP ko,by the way kabibili ko lang din ng PSP,may nakita ako nkalagay sa screen ''To start you have to update the system software,yun ung lumalabas pag navigate ko sa UMD ba yon..
February 2nd, 2007 04:27 PM #4
February 2nd, 2007 05:17 PM #5
bro HG anu ba dapat lagay ko name nung folder ng mga ISO ko?? at anu ba talaga magandang version na gawin ko kasi version ng psp ko is 2.5 eh sabi ng iba downgrade to 1.5 sabi naman ng iba upgrade daw to 2.7 then use devhook may nag sasabi naman sakin from version 1.5 gawin ko daw 3.03OE-a then 3.03OE-B anu ba talaga the best jan sa mga yan??? TIA
- Nov 2005
- 81
February 2nd, 2007 05:46 PM #6brandnew tong PSP ko guys 1.5 version tapos binentahan nya ako ng Devhook ba yon?para daw malaro ko yung mga latest games nila ngayon,nabasa na ng PC ung PSP,kylangan pa pla i-connect ung USB,ngaun problema naman saang folder ko ilalagay ung games na galing sa Dvd?dun ba sa ISO folder o dun sa GAME???
February 2nd, 2007 06:19 PM #7
- Nov 2005
- 81
February 2nd, 2007 06:46 PM #8
February 2nd, 2007 07:02 PM #9
i-enable mo muna yung devhook mo. tapos press HOME + L or R buttons to scroll through your ISO/CSO games.
- Nov 2005
- 81
February 2nd, 2007 08:30 PM #10naku lalo ata na-leche,i don't know how can i get it back,ganito kase ung case kanina,nung binili ko sya nilagyan nya ng isang game,then out of frustration dahil nga hindi ko ma-download yung games from dvd to the console,i tried to format the memory stick and it says all the memory will be lost,ayun pagbalik i connect it again to the PC,wala na yung ISO folder!!!!patay nasira ko na ata!!!all i can see now is the ''PSP FOLDER''....help naman po...
Thread was made nung 2018 pa po sir.
