Results 1 to 5 of 5
November 20th, 2007 06:06 PM #1
Hello,
Help naman. Yung printer ko kasi, darker ang output/print-out kesa sa image sa screen/monitor ko.
Anu kaya gagawin para atleast same yung image color ng monitor at print-out?
Salamat po.
BANNED BANNED BANNED
- 3,790
November 20th, 2007 06:17 PM #2actually it is not the printer problem.. it is more of a monitor problem... check if you have a gamut setting sa video card mo.
try to tweak that.
merun ding mga resources sa PHOTOSHOP how to synchronize the monitor and the printer.
November 20th, 2007 06:30 PM #3
hmmm, actually madalas kong iprint ay yung mga web images or photos galing sa camera. so i believe, since print right away ang ginagwa ko at wala nang edit, good un image ko. pero pangit talaga ang print out.
any detailed info or settings?
thanks and keep them coming.
- 3,790
November 20th, 2007 06:52 PM #4you have to look for a tutorial called "Classroom in a book" ng Photoshop... nasa hiraman yung akin so hindi kita maiguide.
If I recall it right the first step is to calibrate the white. There is supposed to be a system to control the brightness of the "white" page in the monitor to match the papers' white color... ambient light affects this setting (so iba pag naka-ilaw, iba pag natural day light). Kasama dito ang pag-adjust ng brightness and contrast ng monitor.
Next naman ay ang black color calibration. Hindi ko na tanda ang actual steps nito.
Then the rest ay saving the settings.
Sa printer merun din calibration...pero usually controlled eto ng paper that you are using...iba pag plain paper settings at iba pag inject special papers na coated.
November 20th, 2007 07:37 PM #5
thanks.try ko nga maghanap nun.
last time, i did a gamma correction, pero i think that is for monitor setting lang talaga. helpful for web designers or graphic artistists.
kahit mukang "corrected" na ang monitor ko, ganun parin output sa printer.
i better check my printer this time.
yep, malaking factor din ang paper na gagamitin.
hay, hirap i-calib. dami narin nasayang na paper at ink
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
