Results 1 to 5 of 5
- Mar 2010
- 1
March 12th, 2010 03:16 AM #1budget ko less than 25k. need to upgrade my pc. need specs... pls help... d kasi ako marunong pumili ng parts... need to upgrade my motherboard, video card, processor, power supply and RAM.. if meron pa kayong e recomend pls..... need your advice...
- Feb 2008
- 898
March 12th, 2010 08:32 AM #2specify mo kung for gaming ba or what?
What is your present set-up, para malaman natin kung anong kailangan mong i-upgrade...
Tsikot Member Rank 3
- Mar 2004
- 2,053
March 12th, 2010 12:18 PM #3Ahhmmm... I don't think that can be considered an upgrade anymore. That's practically a new PC.
If you don't want to be hassled on picking pc parts, you can check the various PC packages offered by most PC stores (e.g. Villman, Rising Sun, PC Express). They may not be the best, but they're pretty decent, IMO.
You may also want to use those pc packages as your base "setup" then have the store change the parts that you do not like.
March 12th, 2010 12:31 PM #4
- Dec 2008
- 462
March 12th, 2010 07:54 PM #5Aside from budget, it would be better if you specify for what will you be using the computer for. Based on your needs, we can recommend what kind of motherboard, processor, video, etc. would you be needing.
For example, it would be overkill if we recommend a high end video card if you will be using the PC just for internet browsing, office, or non-graphic intensive applications.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
