Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    We're planning to hook up three (3) PCs at home.
    Our choices are:
    - Three (3) plan 999s = 384kbps each PC
    OR
    - One (1) plan 3000 = 1Mbps / 3 = 333kbps each PC
    Pareho lang halos yung price and speed, pero what is more advisable? Sabi ng isang technician, madali lang daw i-split yung dsl, pero yung operator sa 171 says hindi daw maganda ang performance pag naka-split, tsaka hindi raw yung allowed. Mas-advisable daw pag tig plan 999 na lang.
    Quote Originally Posted by Bry
    Our choices are:
    OR
    why have 3 separate accounts for computers located in the same house?
    All you need is one DSL account then a DSL router (example: Linksys BEFSR41 4-port DSL Router which costs P2,350) to distribute the internet to your three computers. You can even have WiFi (wireless) LAN setup but prices for the WiFi lan cards are a bit more expensive than the equivalent wired version.
    Of course, having only one account will mean you are limited that the speed of that account so you might want to get a faster account than 384kbps.
    Take my home setup as an example. I have two desktop PCs and my wife uses a notebook PC. All are connected via RJ45 cables to the Linksys router. Then I have two more PCs in two other rooms which are connected via WiFi to the Linksys router. All five computers are connected to the internet.
    Dec 2003
    router sagot dyan.
    Make the answer clear.
    or
    Three (3) plan 999s = 384Kbps * 3 = 1.15Mbps
    Hindi ko masyado ma-gets mga sagot nyo, hehe.
    Feb 2005
    3 ba phone line nyo sa house? Parang mas ok kung kunin mo plan 3000 then use a router to share internet access.
    or
    Plan 999 is a contract where you are required to sign up for TWO years. The 1st year is P999/month and the 2nd year is at the regular monthly price. Average monthly (over two years) is P1400/month.
    BTW, having three DSL accounts will require you to have THREE PHONE LINES. Thats another cost you will have to figure in if you don't have three phone lines right now.
    Even having three DSL lines will not guarantee redundancy simply because all three are from the same broadband provider.
    BTW, what is the reason why you want 1MBPS broadband connection?.. games? power surfing/downloading? video conferencing? Super-duper ****o downloads?
    If you don't mind buying additional hardware to hook up your 3 pc's into one DSL connection, then kunin mo yung plan 3000 otherwise get 3 seperate 999's na lang provided you have 3 phone lines.
    BTW, a ROUTER is a device that is used to distribute an internet connection to a local area network. You can connect one or more computers to the router.
    We have 2 phone lines right now, pero we're going to apply for 2 more.
    Hehe mahilig kasi kami magkakapatid sa online games. Also for power surfing and downloading, of course.
    Router! Router
    Double post.
    May 2005
    get the plan 3000 .. get a router to hook up your 3 pcs ... that way if you're not using all the pcs at the same time .. you can get more speed for the pc that's on ... the only advantage of having 3 separate plans would be redunduncy .. if one of your lines go down .. the others "might" still be up ..
    i'm not sure why you'd want to get an additional phone line only to satisfy your dsl requirement .. unless you want to have private phone calls which you can use your cellphone anyways ..
    eh kung magkakaroon pala kayo ng additional 2 lines plus 2 existing lines eh yung 999's na nga lang kunin mo!!! at least pag may prob isang line gumagana pa yung dalawa. kasi kung yung iisa lang na plan kukunin mo at nagka-problema, lahat 3 pc's mo alaws na rin connection ;)
    May 2005
    if the reason you'll be getting separate plans is redundancy .. get a pldt and a globlines subscription ..
    Dec 2003
    most of the time pagnagkaroon ng problema, all 3 DSL connections are affected, thats because all 3 DSLs are connected to one and the same base station. unless its the phone line itself thats causing the problem.
    We're not getting additional phone lines just for that. Kailangan na rin talaga anyway.
    EDIT: Sabi sa 171, 'bawal' daw mag-split ng dsl connection. Is this true? Nakakainis kasi sa 171 napaka-inconsistent ng mga sumasagot. Pati speeds ng plans paiba-iba sagot.
    AFAIK di bawal ang splitting kung nasa iisang bahay lang. Ang alam kong bawal kung idi-distribute mo sa mga kapitbahay nyo or gagamitin mo for Internet Cafe.
    May 2005
    WSabi sa 171, 'bawal' daw mag-split ng dsl connection. Is this true? Nakakainis kasi sa 171 napaka-inconsistent ng mga sumasagot. Pati speeds ng plans paiba-iba sagot.
    well .. yung kinabit sa amin ng pldt na dsl router eh may 4 na na lan ports .. this was for plan 999 .. ginagamit lang naman ng parents ko para mag-email .. alangan naman isa lang gamitin ko diba ..
    technically bawal but in practice, they don't even bother.
    So if you don't want to be bothered by the technican/installed about it, just let them install it normally (direct to PC) then after he leaves, connect and configure your router to the DSL modem and surf away.
    Advantage of using a router are:
    -sharing of a single internet connection to multiple computers
    -protection to the computers from outside hackers (firewall)
    -simple to configure and more reliable (than using a didicated NAT server)
    -small size and low power requirements (i have my router attached to the wall)
PLDT myDSL - Help!
