Results 1 to 10 of 17
- Jan 2007
- 4,459
April 20th, 2009 06:14 PM #1Don't know the right term, pero eto ung no need na mag-dial. Helpful if you leave your laptop and then magdisconnect, automatically magconnect na. Pati pag startup.
Bago kasi modem ko pinalitan kanina ng PLDT, ZyXel. Sabi nung pumunta nakaksira daw ng modem ung automatic kasi legacy pa daw ung line ko
Now I tried to access 192.168.1.1, pero hindi na ma-access. Dun kasi sinet dati nung gumawa ung auto mode ata.
April 20th, 2009 06:21 PM #2
DHCP setting i think is what you are referring. the router/modem will automatically reconnect its connection if it is interrupted or disconnected.
My PLDT DSL have this setting, so i leave my router on 24/7
April 20th, 2009 07:17 PM #3
If its 192.168.1.1 then that must be a linksys router.
This is easy. Reset your linksys router by pressing a small recessed black button located at the back of the unit. Use the Linksys setup cd to setup the sharing of internet connection.
- Jan 2007
- 4,459
April 21st, 2009 01:50 AM #4I don't have a router. Modem lang to ng PLDT.
How do I do it? Ung dating pumunta kasi dito ganon ang ginawang setup. Ung pumunta kanina sabi nakakasira daw ng modem un kasi hindi naman daw pang-ganon ung line ko since legacy daw.
April 21st, 2009 08:45 AM #5
Yes the reason you were able to access 192.168.1.1 is bec. the device pldt provided you before is probably a modem/router. This Zyxel is just a modem so you there is no setup screen to access. Same one that I have right now. You always need to dial-up even with a router. Its just the router automatically connects for you instead of you having to dial it manually every time you disconnect. Get a router to share your connection with other pc in your house.
BANNED BANNED BANNED
- Jul 2003
- 2,267
April 21st, 2009 09:21 AM #6yung sa amin ganyan ZyXel ba yun. automatic siya magconnect sa internet.
yung dati pala ay hindi ganun?
- Jan 2007
- 4,459
- Feb 2009
- 7
April 21st, 2009 10:31 AM #8Sir, pwede pong magtanong anong setting po ba ung gusto mong palitan? ung setting ng PLDT modem mo?
- Jan 2007
- 4,459
April 21st, 2009 11:22 AM #9Ayoko nung dialer setup. Gusto ko when I restart connected na agad. Para ma-avoid ung hindi pag-move ng downloads pag nadisconnect and I'm not in front of my laptop
April 21st, 2009 12:39 PM #10
No need na talaga mag dial pag DSL ka. The Zyxel modem provided by PLDT is also acts as a DHCP server. Hindi nakakasira ng modem ang automatic. Kalokohan yan.
Lucius, gumamit ka ng cross-cable, lagyan mo muna ng static IP yung laptop mo ng 192.168.1.2. Walang gateway. Tapos tsaka mo browse http://192.168.1.1. Default username is admin. Password is 1234.
Ang ginawa kong setup sa bahay, bumili ako ng wireless router para yung modem act lang as modem and yung wireless router acts also as the DHCP server, marami pa pwedeng connect and hindi pa wired.
Hybrids and EV
