Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    guys, na-try nyo na ba windows vista ultimate? any comment about this operating system? parang mahirap gamitin pagdating sa mga softwares? hindi compatible.... any advice..... thanks
    Jan 2003
    (note: nakigamit lang ng laptop na may vista)
    medyo hindi pa hiyang ang mga current games sa vista.
    and ang lakas kumain ng RAM. 2GB ka ata dapat pag vista na OS mo eh.
    Quote Originally Posted by A121 View Post
    yup! pati other softwares, d compatible
    Quote Originally Posted by ssaloon View Post
    ang bilis naman sa akin sir,
    eto po spec ng pc ko sa house:
    1G memory
    160HD sata
    256mb pci 128bit
    core 2 1.86
    DVD-R & CD combo
    files ko nasa other Harddisk....
    needs ko lang po other comments baka meron solution/advice sa other softwares.
    Feb 2005
    Okay ang Windows Vista. Nakakaaliw lalo na yung Windows Flip. Also, Windows Media Center is one of the key features of Vista (Ultimate and Home Premium edition. You can setup your own digital entertainment library right from your desktop PC.
    If you are going to install or upgrade to Windows Vista, make sure na merong drivers yung mga device mo. Sometimes, nagagamit pa rin yung pre-Vista drivers(XP and 2000). Check mo rin kung compatible ang apps mo. From my own experience, di namin ma-install ng maayos ang Nero 7 premium pero certified naman sya for Windows Vista.
    For Video and audio playback for most formats, make sure that you download and install Vista codec pack.
    Feb 2005
    In addition to that yung Video memory.
    Some info from the net.
    System/Hardware Requirements:
    Minimum:
    - Processor 800 MHz 32-bit (x86)
    - System Memory 512 MB.
    - GPU SVGA (800x600)
    - HDD 20GB
    - Graphics Memory 64mb
    - Hard Drive 20GB (free space 15GB)
    Recommended:
    - 64-bit (x64) processor 1 GHz 32-bit (x86) or 64-bit (x64) processor
    - System Memory 1 GB
    - SVGA (1024x768)
    - Graphics Memory 128mb and aero compatible
    - HDD 40GB (free space 15GB)
    Pagdating sa memory and storage, the more the merrier. Yung nga lang di masaya ang bulsa. hehehe
    yun nga po sir, nero 7 d mainstall also the adobe postscript printer, dahil most of my projects save ko sa acrobat. is there any way na magamit ulit yun other softwares? is theres a difference between pirated OS sa original OS?
    Feb 2005
    Quote Originally Posted by IIE View Post
    For Nero, check these out. Baka try ko rin mamaya.
    http://apcmag.com/node/4021
    http://forums.afterdawn.com/thread_view.cfm/466160
    Yung sa adobe, try searching from the net.
    Difference between original and pirated OS? Pareho lang sila unless yung pirated is hacked version.
    Jul 2006
    Wag na tayo masyado magreklamo kasi 1,2,3 years from now yan na rin ang gamit nating OS
    Quote Originally Posted by mikmik316 View Post
    ? sir, d po ako nagco-complain, im looking for a solution for my other softwares to run in vista os....
    Jun 2006
    OK naman performance nya sa PC ko (athlon XP 3000+, 1GB RAM) pero napansin ko lang na malakas kumain ng disk space pero maliban dun eh wala pa naman akong napapansin na hindi maganda.
    Jun 2006
    hanapin mo yung compatibility feature ng Vista para masubakan mo kung gagana yung ibang apps mo. Naitanong ko kasi sa Microsoft Software Evangelist yung issue regarding sa compatibility ng older programs and he replied na gamitin daw yung compatibility feature na kasama sa Vista. Unfortunately eh nakalimutan ko na kung saan banda nakalagay yung feature na yun pero try mo na lang sa help or DL ka ng mga Vista ebooks.
    a ganun po ba? thank you po boss tabong....
    Jun 2006
    did someone say Vista? hah!!! don't even get me started.... :furious:
    Jul 2006
    There are several ways to run your old software....
    1) Virtualization - You have to run Virtual PC 2007 on top of Windows Vista so that you can install Windows XP and thus your software
    2) Use compatibility mode to "trick" the software that its running Windows XP while you are still using Windows Vista
    3) Dual boot Windows Vista & XP... Install only your old apps in XP and the others in Vista...
    Alam naman nating lahat na getting know the latest software will give you an early headstart to "impress" your boss & peers... So better stay ahead na rin and use Office 2007... The more you get acquainted with new software, the earlier you can try tinkering with it.
    Jan 2003
    yes... sa kaibigan ko, (nakigamit na naman) 76% ng 2GB RAM nya ay ginagamit pag naka-idle. considering naka norton pa sya.
    Feb 2005
    Quote Originally Posted by tabong View Post
    If I'm not mistaken, yung parang sa XP yata yan. Right click mo lang yung application (.exe) then Properties -> Compatibility tab, then piliin mo na yung compatibility mode.
    Ang problema, hindi naman lahat ng old programs ay napapagana ng compatibility mode. Yung iba, gagana pero maiinis ka kasi magloloko din yung apps pag ginamit mo na.
    Feb 2005
    Nice suggestion.
    I've been a tad miffed by the sudden disappearance of XP Home Upgrade from store shelves. I needed to buy a copy because my daughter seems to have lost the XP Home cd on her pc. The 5-year old hard drive in her pc decide to do the clicking thing and croaked. I looked around for the good part of the day and only saw the full version of XP Home which is $200. $200 for an old OS is a bit too much for me. So....no way Jose.
    I decided to buy Vista Home Basic along with a new hard drive.
    Installation went fine. I thought it'd be straight forward which it was for the most part. After the install, everything looked peachy until I noticed I can't get on the internet. Looking around, I found out the 3COM 3C905TX lan card didn't have any native Vista drivers (along with no Realtek sound drivers).
    That got me on a cussing mood right about the time I was posting the Mac vs Windows vs Linux thread.....
    I then decided to see if the XP driver for the 3C905TX card would work. Sure enough, it did. Once that was done, I had internet and was able to update the Realtek sound with Vista drivers. Minor stuff, really. But, that saved me from having to buy a new LAN and sound cards. MS..... I just don't know whether to love em or hate em.
    Dec 2004
    You can use any Home Edition CD as long as it's the right version (retail, or OEM, whichever you have). Use the serial number stuck on your computer's case. You did stick it there, right? I've done this before on countless OEM PC's when I didn't want to install all the crap that comes preinstalled with the OEM recovery discs.
