Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jan 2011
    anong magandang gawin dito sa opisina namin. hirap ng signal ng cellphone, di ka makatawag kung di lalapit sa may bintana. talagang dead spot, tatlong building magkatabi, nasa gitna kami.. nagkabit na kami ng signal amplifier, wala din.. ang nakapagtataka, may signal bar din naman, di nga lang maka send message at call. any suggestions? TIA
    Thats a network issue. Call your network provider to fix the cell site.
    Jan 2011
    ah ok sir. thanks so much. sorry for the ignorance. ang sabi ng i.t. namin kasi, dahil sa building talaga.
    Jun 2010
    Quote Originally Posted by shelu View Post
    Hindi kaya may signal jammer dyan sa office nyo sir?
    Jun 2015
    Same experience here sa house. May signal bar pero kapag tinawagan mo ung number cannot be reach. I even reported it sa network provider ang sagot sa kin
    magsurvey daw ako sa kapitbahay if they are experiencing the same situation. Malakas naman daw kasi ang signal nila sa area namin so baka fone ko daw ang problema.
    Quote Originally Posted by kyle_armie View Post
    nangyari sa akin yan. what i just did is to hard reboot the phone and it worked.
    kay TS, ibang kaso, dahil lahat sila ganun...... it could be a signal jammer dahil full bar ang signal eh.... kung weak ang signal, sa telco yan.
    pero i would suggest to the TS to report it sa telco na din so they can take appropriate action...... kung talagang may signal jammer dyan sa area, bawal yan eh..... unless properly authorized by NTC.
    Jul 2012
    Singit ko na din dito yung mobile data signal. Kapag nasa loob ng bahay wala, kapag lumabas ka naman sa garahe 4G. Any solutions?
    Quote Originally Posted by leodawesome View Post
    In the US, AT&T provides 4G booster boxes for some areas. Not sure if Smart/Globe offers such solutions.
    may signal jammer dyan ang signal naman ng telepono hindi line of sight
    Jun 2015
    pero i would suggest to the TS to report it sa telco na din so they can take appropriate action...... kung talagang may signal jammer dyan sa area, bawal yan eh..... unless properly authorized by NTC.[/QUOTE]
    Ginawa ko na un pati pagrereformat ng phone. Same pa din.
    Sep 2005
    parang sa motel lang.. parating walang signal.. hehehe
    Oct 2009
    mag request kayo ng signal booster sa opisina nyo.
    kagaya ng ng nasa parking ng 168 mall
    kahit na sa ilalim na ilalim may signal parin
    Jan 2014
    Wala kayong indoor antenna sa building? Ayun yung mga hugis cone na kulay puti at madalas may sticker ng telco pag nag punta ka sa mga malls may mga ganun nasa ceiling nakalagay. Repeater lang yun bale na naka connect sa amplifier para sa mga dead spot ng building. Malakas talaga kasi yung drop ng signal kapag madaming interference. Dapat makipag coordinate yung building admin sa telco. Hindi dapat dahilan yung crowded kasi lugar nyo dahil pwede naman lagyan ng mga ganun halimbawa na nga lang ulit yung mga malls. Napakalawak pero kahit nasa gitna ka may signal at madami pang tao nun ha
    Tawag dyan, Inbuilding Solutions. Request nyo sa Telcos. Usually yang bldg admin nagrerequest nyan.
    Quote Originally Posted by luis_ View Post
    Ganito yung mga cone shaped na in bldg antenna sināsabi ni luis.
    Feb 2005
    sinong magsoshoulder ng gastusin pag pinakabitan ng mga cone type signal booster? telco or building owner?
    Yes they can do that (boost the signal of cellsite signal) and you just have to report to their hotline at baka magawan pa paraan. Pero kapag booster na machine ang kelangan na, dapat mataas traffic nang usage para kabitan ang isang bldng. Try niyo mag-request (lalo na kung yung building woners/manager mismo gumawa nang request) at baka puwede naman kayo lagyan signal booster sa bldng niyo.
    Quote Originally Posted by box_type View Post
    depends on the arrangement...... pag entire building, yung building owner.
    pag sa area nyo lang, kayo...
    Jul 2013
    palagay ko, walang jammer diyan dahil pwede sa labas ng window.
    your best bet, install an outdoor ant. its called a colinear ant; yong 8 elements.
    i'm not sure about the freq; maybe 900mhz, 2.48ghzz or 5.28ghz. before it was 900mhz. magpunta ka sa raon and buy an 8 element colinear ant. of course, it should be installed outside the window, if it works inside, di ok then buy the cleapest cp and use it as your general calling cp. medyo hassle at tedious but it is the cheapest setup.
    by the way, the ant cost P200 -1500 depending on q.
    [COLOR="silver"]- - - - - - - - - - - - - - - - - - - - - -
    Jul 2013
    additional info: consult an electronics technician at magpagawa ka ng ground plane ant w/c should cost much lesser. narealized ko, pwede pala kung outside the window. a simple gp will do the trick.
    95% of the cost goes to the cable, either 50 or 75 ohms. buy an ant assembly with a proximy/piggy back connection.
no signal even with visible signal bars
