Originally Posted by wildthing
yes, I agree. MAC is best for graphics. Get the new model with Duo. You wont regret it.
ok ang dual core. my DELL (D610 lang ito) is ok for heavy programming and database operations. gaming is fair though kasi 64MB lang ang Video RAM ko. basta kung kaya i-stretch ang budget get the laptop which has the most memory, storage, graphics capabilities, etc. in the long run it will reap you benefits rather than disappointments.
additional, you might opt to buy a laptop that has an internal multi card reader ;)
MacBook Pro for me! hehe
now that Windows XP will run on an Apple, no more reason not to get one. :D
Dual-booting is not always the best choice nor the most convenient for many people. Most people should do ok with a pc laptop running XP (or later on, Vista).Originally Posted by mbt
Personally, I rather buy a pc laptop like one of the HP laptops listed and later on decide to buy a Mac Mini (if it's worthwhile enough for the user). At least, the user can use both at the same time instead of alternating between two operating systems.
Not sure about the Pavilion models of HP, but future proof your purchase by getting the Dual Core Intel Processors. Centrino is already passe.Originally Posted by Liz
Watch the weight. 15" is classified as desktop replacement. 6lbs and up may kabigatan na po iyan pag dinadala sa labas.![]()
mac is "good at heavy graphics", for me d ata, it depends, at hassle pa ung papalitpalit ng os, my cousin do have powerbook we try to compare the performance side by side with almost same specs ( mac laptop with a little bit higher specs ), result was almost the asme, mas mabilis lng ung mac ng 3-5 secs. ( we opened 3gig file nd resampling big images using photoshop). no offense sa mga naka mac, opinion ko lng ito.
pag ng purchase ba ako ng may winxp home edition, pde ko b install pro edition o later on ibang version na ng windows na mas bago?
another, overall hp o acer is better? nd ung video memory b d upgradable?
Baka po yung Mac na PowerPC ang ginamit nyong pang test. Di po talaga sya nagkakalayo sa speed as compared sa intel laptop. but the new Mac Duo using Intel processor will definitely outperforms most of the intel laptop w/ the current specs including the specs you mentioned.Originally Posted by Liz
Kung WinXP home ang license mo ay hindi sya magiging legal kung WinXP pro or Vista ang iinstall mo. And I don't think that you can upgrade laptop video card.
for me sa 3 options mo this is the one i prefered for you. kung papipiliin mo ko sa 3 options mo. but if i were you kuha ako ng macintosh the best in graphic technology. but "BUT" dont buy laptop for graphic design use, kasi some monitor like laptop is not capable for color resolution. i-calibrate mo pa kasi yan monitor (video) hindi lang po layout ng layout you should know the color sheme ng design mo for your client.HP Pavilion dv5101tx:
-intel core duo 1.66GHz, 2MB L2 cache, 667MHz FSB
-512MB (1 x 512MB) DDR2 SDRAM (667MHz)
-15.4" wxga
-NVIDIA GeForce® Go 7400 256MB video memory
-100GB SATA (5400 rpm) HD
-dvdrw![]()
Hmmmm. A thought just occured to me. Liz? Sounds familiar.....
Liz, is that you from the "other" forum(s)? If it is, then you should recognize my handle and I'd also have a clearer picture of what you plan to use the laptop for.
Also.... Kumusta! I've been hanging around here and brushing up on my Tagalog. Puwede na rin, eh?![]()
go for the MacBook Pro. price should start at $2000 or php140k...
15.4-inch: 1.83GHz (MA463LL) or 15.4-inch: 2.0GHz (MA464LL)
Processor 1.83GHz Intel Core Duo / 2.0GHz Intel Core Duo
Memory 512MB (single SODIMM) 667MHz DDR2 SDRAM (PC2-5300) / 1GB (single SODIMM) 667MHz DDR2 SDRAM (PC2-5300)
Display 15.4-inch (diagonal), 1440 x 900 resolution, TFT widescreen
PCI Express Graphics ATI Mobility Radeon X1600 with 128MB of GDDR3 SDRAM and dual-link DVI / ATI Mobility Radeon X1600 with 256MB of GDDR3 SDRAM and dual-link DVI
Video Built-in iSight Camera, DVI, VGA (DVI to VGA adapter included)
Audio Combined optical digital input/audio line in, combined optical digital output/headphone out, stereo speakers, microphone
Hard disk drive (4) 80GB Serial ATA/100; 5400 rpm / 100GB Serial ATA/100; 5400 rpm
Slot-loading optical drive SuperDrive (DVD±RW/CD-RW)
Ethernet Built-in 10/100/1000BASE-T (Gigabit)
Wireless (3) Built-in 54-Mbps AirPort Extreme (802.11g); built-in Bluetooth 2.0+EDR
Modem Apple USB Modem (sold separately)
Input Apple Remote; full-size, illuminated keyboard with ambient light sensor; Scrolling Trackpad
Expansion One FireWire 400, two USB 2.0 ports, and ExpressCard/34 slot
Weight 5.6 pounds
Footprint 14.1 x 9.6 inches
Thickness 1.0 inches (2.59 cm)
iie, im a graphic designer, your ryt, laptop screens are not accurate in colors, i'm planing to buy laptop so i can bring my work anywhere, i have desktop pc dun ko inaayos ung tamang color kasi un ung naka calibrate sa printer, laptop para sa presentation at editing lng ng mga flaws sa graphics. thanks.
btw, mac is not an option for me, pls suggest other brands that have a good specs at a 80 - 90k price range. thanks.
i eventually decided to get an Asus A6Q model. specs are:
- intel centrino duo tm2300
- intel 945pm expess chipset
- 15.4 wxga color shine lcd
- 1 gb ddr2 ram
- 100gb hdd (5400 rpm)
- built in web camera 1.3 mpx
- ati mobility radeon x1600 with 512mb ddr3 hypermemory
its got a great design, black-gray magnesium finish. its almost like the mac book pro in terms of specs, but almost half the price. specs are power-packed, see if it would be enough for your computing needs.
*Liz -
Links which might be helpful -
www.notebookreviews.com
www.notebookforums.com
If you have US contacts or know someone (flight attendant?) who travels there often, you may want to consider having them buy it for you and bringing it over for a nominal fee. It will end up a lot cheaper. E.g. I bought a Fujitsu P7010 last year at $1700. Comparable model is being sold here for P120K. HongKong might be another source but I am not that familiar with prices there.
Most on-line sites such as dell, compusa, alienware also have regular sales or offer discount coupons (www.techbargains.com). The savings can be substantial. (e.g. We just bought a Dell Inspiron 1300 - Celeron 1.50, 512MB, 15.4", 40GB, 802.11b/g, DVD CDRW for only $499 including free shipping. Online coupon offered free upgrade to 15.4" and 512MB). Not bad for an entry level unit.
But one thing to watch out for are dead pixels. Resellers have different policies re this so you may want to inquire first. So far, we have been pretty lucky and most of the notebooks we have bought had perfect LCDs.![]()
As for after-market support, most name brands hold up pretty well unless they are abused or mis-used. For popular models, even without an international warranty, you should be able to have them repaired locally.
Also, screen sizes have increased significantly lately. Recent models tend to have widescreen LCDs, with 15.4" being popular these days. There are also models with 17" and 19" screens. But these tend to be on the heavy side already. Depending on your editing requirements and presentation needs, you might want to find a compromise between LCD size and weight.
Lastly, depending on what type of graphics you do, some software are optimized for certain graphic chipsets. If this applies to you, you may want to take note of the specific chipset. If your graphic work consists primarily of static images (e.g. photoshop) and simple AVPs, then the amount of RAM (and video RAM) becomes more critical.
* Aceshark - Alienware offers discount coupons. Also, if you shop on-line and leave your item in the cart for 24 hours, you will receive an email offering another $50 discount.
* Nitrox - I just got 5672WLMs for my two sons. One is into 3D modeling and the other into computer forensics. Both are heavy into games. While these are good enough for 3D modeling, they tend to struggle with some new games. Specs include 2GB RAM and x1400 256MB. In hindsight, perhaps we should have upgraded to 512MB for the video. We got them at compusa for $1499 - less $150 rebate = $1359. No sales tax as we have a reseller permit.
*Liz, we can help you to check the prices here in HK. Actually, we do buy Laptops for our friends/clients there in Manila.
bro Rediesel, will reply you in due course. Need to check the price.Originally Posted by Rediesel
bongliza, whats the price of : hp pavilion dv5102tx, acer aspire 5672wxmi and acer aspire 5562wxmi?
you mentioned that you do buy laptops there for your friends here in the philippines, what's the setup? how?
and what is this dead pixels?
