Results 11 to 20 of 21
- Nov 2009
- 3,509
October 23rd, 2010 12:00 AM #11^^ na curious din ako sa bridge segment, parang ad hoc wireless.
The problem seems to be easily resolved by using static ip. If you really want DHCP at the office, try inserting another router after Router3-using different network-IP over the LAN.
October 23rd, 2010 07:40 AM #12
Router 2 & 3 cannot be connected by LAN cable. May thread ako dati dito asking about external LAN cable, masyadong mahal and delikado sa lightning ang mga sagot sa thread ko.
My office is across the street from my house. Router 1 is in my room which is not facing the office so I need another router (router 2) that will have line of sight with router 3.
I don't have a proglem with DHCP per se. My problem is, there are times that the plug of router 2 gets unplugged accidentally, sometimes by the maids or the kids. If this happens before the computers in the office are turned on, then the office computers won't be assigned IP addresses, and they cannot see the server nor connect to the internet.
October 23rd, 2010 02:01 PM #13
October 23rd, 2010 03:25 PM #14
Tried it. Won't work.
I'll have to go back to the house to reconnect the unplugged router to have Internet access again. Although the network in the office side won't be affected if the router 2 was unplugged after all the computers in the office have already logged in.
October 23rd, 2010 05:05 PM #15
October 23rd, 2010 05:47 PM #16
Worst case, as soon as the wireless bridge is up, issue the following commands on all office PCs so you wouldn't have to reboot them:
ipconfig -release
ipconfig -renew
You can also put them in a batch file and place it as a shortcut on the desktop on all office PCs. Instruct your staff to double-click on the icon to refresh/restore the IP settings. For more information: http://stephensulzberger.wordpress.c...ase-and-renew/
October 24th, 2010 02:16 PM #17
Secure the plug. Firmly. You can use glue, duct tape, screws, specialized type of plugs etc.
- Nov 2002
- 1,326
October 27th, 2010 04:56 PM #18I haven't read through all the material on dd-wrt, but it seems my original idea wouldn't fit in the model you have..
pag isipan ko pa.. but the suggestion above to really secure the outlet is very practical and doable.. latag lang ng cable and extension na talagang maayos, para maiwasan yung unnecessary na mabatak yung saksakan...
i would also recommend assigning a fixed IP address for the server (nabanggit mo you have servers sa office side ng LAN).. at least that way you have something definite na sure ka lagi yun ang ip address...
- Nov 2002
- 1,326
October 27th, 2010 06:52 PM #20earlier you mentioned that router 1 is the one giving the IP addresses... if your ip range being used is 192.168.A.xx - 192.168.A.zz, then the ip address of that server should be an address outside of the range of A.xx and A.zz, and also not the same as the ip addresses of router 2 and router 3...
kung windows based ang server mo (NT, 2k3, etc), you can go to Start -> Settings -> Control Panel -> Network Connections -> Local Area Connection -> Properties -> TCP/IP -> Properties
You set the IP address and the subnet mask (same subnet mask as that on your dhcp server on your router 1).
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
