Results 11 to 20 of 23
- Sep 2006
- 19
December 9th, 2006 10:22 AM #12siguro nga signal loss, pero based on experience I have used 3 network cables with inline socket adapters to make a 20 meter long cable more or less and it's working fine. I'm beginning to be suspicious with the inline socket adapters that I bought. Just to make sure I'll try the remaining cables in my box that has the same length and I'll try another RJ45 to RJ45 inline socket adapter. BUT, if there are anymore suggestions...please don't hesitate to post. I'm open to any solutions. Reasonable solutions I mean.
- Apr 2005
- 28
December 9th, 2006 10:38 AM #13Sometimes, its the inline socket problem. Used some of those before, erratic anf connection. Also, try different ports on your router or hub. ie-uplink port>reg port.
December 9th, 2006 10:43 AM #14
Minsan may mga cheap CAT5 cable na talaga di gumagana pag mahaba na sya (mga fake cables) I had experienced the same scenario. Try to get BELDEN or AMP cable w/ a good RJ45 and it will work.
- Sep 2006
- 19
December 9th, 2006 10:56 AM #15How much does a BELDEN or AMP cost?*wrcastro_ph
I'll try your solution too bigfoot.
December 9th, 2006 11:55 AM #16
did you check the color coding of your cable-socket connection? diba may straight through and crossover patch cable yan, baka lang naman...
- Sep 2006
- 19
December 9th, 2006 11:53 PM #17
December 10th, 2006 12:10 AM #18
maybe you would like to try (buy) another adapter? baka may nag loose connection na sa luma mong adapter.
- Sep 2006
- 19
December 10th, 2006 12:50 AM #19I guess, that's what I'm going to find out. I'll be posting again soon if it didn't work.
- Apr 2005
- 28
December 10th, 2006 09:49 AM #20Belden is very reliable, especially if the distance is quite long. Its around 15/meter sa Raon, have yet to see it sa computer shops selling by the meter. They usually sells Belden by the rolls.
high idle RPM at engine start
