Results 1 to 20 of 20
    Sep 2005
    Do you use or have used *******? I'm trying it out right now. Any feedbacks?
    http://www.*******.com/
    http://*******.sourceforge.net/
    Causes my PC to hang or slow down when I tried using it two years ago.
    I am currently using u******* which is stable and not a memory hog.
    http://www.u*******.com
    im using it now... more than a 9 months ko na ginagamit so far so good...
    I really like the ******* interface but it eats too much Ram. Java rice kasi eh...
    the lowest and most stable is u*******. also the best among DHT, trackerless *******s.
    but my favorite is the old ******** .70. I still get lucky constant in my speed here.
    Aug 2003
    ******* is fine. its what i use on Linux and Mac.
    Sep 2005
    What other ******* clients do you guys recommend, aside from ******* and u*******? Yung madali lang gamitin since i'm not a "network techie" guy.
    u******* and ********.
    I also use *******, I am satisfied with it...
    Apr 2008
    i used both u******* and *******. observations ko lang e mas marami memory kinukuha yung ******* compared sa u*******. yung newer version naman ng u******* may prob sa tracker kaya kahit upload ka ng ilang weeks yung ratio mo ganun parin. 1.16 version ata yung maganda basta hindi yung latest pag dating sa u*******.
    Aug 2005
    I was thinking of using *******, in fact I downloaded the app but haven't installed it yet. Been using u******* and am satisfied with it. No system lag. Configuring it with some tweaks ensures fast download. See http://triponic.com/guidestutorials/...rent-settings/
    Aug 2005
    Quote Originally Posted by judoman View Post
    :offtopic: *judoman, i think it's u******* 1.6.1
    You can download all versions of u******* here: http://www.**************/download_u*******/2253/
    Sep 2004
    If you are running a Linux distribution you might want to try Transmission, the new lightweight bittorent client for Linux. I am using SmartBro and Mandriva 2008.1 "Spring" Linux.
    Transmission is very simple. Kahit not forwarded yung port (locked by SmartBro and nothing you can do about it) I have successfully downloaded a 750MB movie overnight the very first time I used it. No errors. All at default settings which were few anyway and despite the slow download rate of SmartBro as compared to a DSL line.
    I suggest you try a few of these bittorent clients to find one with the best probability for a successful download. I did and discovered Transmission is best for my setup.
    Aug 2003
    i've already downloaded transmission a couple of weeks ago. nakakalimutan ko lang gamitin para ma-compare sa *******.
    Apr 2008
    *leinahtan
    thanks sa pag-correct. mahina ang memory. =)
    yup.. yan po yung version na gamit ko.
    Sep 2005
    Thanks pare! Ok naman pala ******* but my problem now is HD space!
    I'm gonna get another HD soon though!
    Sep 2005
    Quote Originally Posted by CtrlAltDel View Post
    Ok yan ah! Is it available for Windows? Sometimes kse mabagal yung download ko sa *******. I'll also try ********, like ghosthunter recommends.
    Quote Originally Posted by russpogi View Post
    I bought a 250gig HDD just to hold all my downloads.
    Sep 2004
    Walang version yung transmission sa Windows. Linux at Mac OS lang siya pwede sa ngayon. Maganda yan kung merong pang makapag-compare ng bilis sa ibang bittorent clients. Before transmission, I never had made a completed file donwload with *******, Bittorent (Official client), K*******, and bittornado. Talagang mabagal (sa system ko) ang mga ito: naglalaro lang yung download speed betweed 1kBps and 2kBps, on the same source, same file. One time sa official Bittorent client, I started a ******* download at 8PM and it was finished at 1PM the following day. Meron pang errors rendering the file useless. Again, this could also be user-error on my part.
    Subukan mo lahat, heheh. As you know, there are quite a bit of variables that affect ******* speed. As for me, transmission is good enough. Meron ulit akong na download na bagong movie, overnight lang.
    ******* not ok with Windows Vista my Wifi USB keeps on turning off
    ******* highly recommended on Macs however
    i'll use u******* na lang sa vista
    Aug 2003
    i just finished testing Transmission for Mac. i must say im not satisfied with it after having used ******* for a long time.
    kulang ng advanced management for the ******* entries. sample: there are no ranking/priority for seeding and downloading; you can only pause and unpause the entry. wala din force tracker update for each *******. kulang din ng estimated time to download.
    i think i'll stick with the heavier ******* for the meantime until Transmission gets more mature.
Feedback: ******* ******* Client
