Results 31 to 40 of 72
Threaded View
October 21st, 2007 08:48 PM #1
Bought this from HK a few days ago:
Philips 220CW Widescreen LCD HD Monitor
Picture/Display
LCD panel type 1680 x 1050 pixels , Anti-glare polarizer , RGB vertical stripe
Panel Size 22" / 55.9 cm
Effective viewing area 474 x 296 mm
Pixel pitch 0.282 x 0.282 mm
Brightness 300 cd/m²
Contrast ratio (typical) 5000:1
Display colors 16.7 M
Viewing angle 160º (H) / 160º (V) , * C/R > 10
Response time (typical) 2 ms
White Chromaticity, 6500K x = 0.313 / y = 0.329
White Chromaticity, 9300K x = 0.283 / y = 0.297
Maximum Resolution 1680 x 1050 * 60Hz
Recommended Resolution 1680 x 1050 * 60Hz
Video Dot Rate 205 MHz
Horizontal Scanning Frequency 30 - 93 kHz
Vertical Scanning Frequency 56 - 76 Hz
Aspect ratio 16:10
sRGB Yes
Connectivity
Signal Input Analog (VGA) , DVI-D
Video Sync Input Signal Composite Sync , Separate Sync , Sync on Green
Video input impedance 75 ohm
Sync input impedance 2.2k ohm
Video input signal levels 0.7 Vpp
Convenience
Convenience Enhancements On-screen Display
Monitor Controls Auto , Brightness (Left) , Contrast (Right) , Menu , Power On/Off
OSD Languages English , French , German , Italian , Russian , Spanish
Other convenience Kensington lock compatible
Plug & Play Compatibility DDC/CI , sRGB , Windows 98/ME/2000/XP/Vista
Regulatory Approvals CE Mark , Energy Star , FCC Class B , SEMKO , TCO '03 , TÜV/GS, TÜV Ergo , UL/cUL
Tilt -5° to 25°
VESA Mount 100 x 100 mm
I'm now using 2 LCD monitors side by side using DualView. I can play full screen games or watch a movie on one monitor and browse the net or do other things using the other monitor. Cool!
My other monitor, btw, is an Acer AL1751 17" LCD (not widescreen).
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
