Page 13 of 20 FirstFirst ... 391011121314151617 ... LastLast
Results 241 to 260 of 400
    Aug 2004
    #241
    Labo ng Ace sa Greenbelt 1 wala daw silang GES.
    #242
    ^meron sa true value glorietta
    Oct 2011
    #243
    Quote Originally Posted by weszt View Post
    sir 10 yrs warranty pati ata leakage kng meron man sagot nila tawagan m lng d ko alam kng mahal e pero sure yan kahit mahal bawing bawi ang ininvest mo consultant ako pero d ako nagbebenta nian. haha prenesent lng smin.
    Posted via Tsikot Mobile App
    nagpa quote na ako sir. ung sola master series.... may 8" roof flashing and 24" extension tubes plus prismatic diffuser na kasama. overall nasa 41k including installation for one(1) unit solatube. nag tanong ako kung meron silang solar panel para at least pwede ko rin gamitin sa gabi ung solatube pero wala silang available.
    Aug 2004
    #244
    Ye baka makadaan kami mamya. Apat na kasi na CFL sa bahay ang kelangan palitan.
    #245
    GES na 2 year warranty kunin mo. madali magpa replace kung may problem.
    Firefly naman na 3 year warranty mura. hindi ko lang alam if madali ba magpapalit if may problem.
    Aug 2004
    #246
    Yep may GES 2 years kami sa bahay. Nagsurvive naman sa patay sindi sa banyo. Since then I decided na when a CFL dies I'll replace it with a GES.
    Aug 2009
    #247
    isang solatube lng 41k?!! mahal pala talaga. computin nyo bill nyo kung ila n ROI, kasi malaki matitipid nyo sa electricity bill kung puro metal halide gamit nyo. in the long run kahit mahal winner pa din tipid sa kuryente. hehe nakita ko brochure nila sa mga ordinary office meron sila LED sa gabi integrated sa light fitting.
    Hindi advisable ang solar panel masyado mahal, hindi nmin inaadvise gumamit nun. nag feasibility kc boss ko jan.
    tawaran mo sila kung masyado matagal ROI pakita mo computation mo. hehe walangbibili nian kung sobra tagal ng ROI.
    Jan 2009
    #248
    The first LED lights I've used for the home have been the NXLED. Subsequently, I chose GES on future purchases primarily because of their lower price.
    Here are a couple of tips:
    What I've noticed is that GES "daylight" LEDs have a more pale/washed out color temperature that can be hard on the eyes. The NXLED on the other hand, has a more natural, slightly warmer tint.
    That said, if you want to illuminate living areas with "daylight" LEDs (living room, common room, dining room, etc.) where people tend to linger, you may want to consider the NXLED. For everything else, GES daylight is fine (ie. storage areas, hallways, etc.)
    For the bedrooms, I purposely chose "cool white" for the main lights and "warm white" for the corner lights... all GES.
    Oct 2011
    #249
    Ito breakdown: 5k Solatube, 5.5K 8" Rook Flashing, 4k 24" extension tube, 3.5k prismatic diffuser, 3k top angle adapter. Plus pa mobilization, installation charge and vat. Ang mahal sir. Anyway, nagpa quote lang muna ako hindi ko pa nakakausap at hingan ng discount.
    Aug 2004
    #250
    Thanks for the tip!
    Mali nga ako ng bili nung una. I got the daylight 7W and di namin type sa kwarto kaya sa banyo napunta. Buti na lang daylight din yung CFL na napundi don kaya sanay na kaming yellow ang tiles
    My next bulbs will be for the room so they will be cool white
    Aug 2009
    #251
    ok sir. pero mahal parang hindi sya papatok sa market natin pag ganyan ka mahal
    Aug 2009
    #252
    Thanks for the tip!
    Just my thoughts, I don't recommend using LED light.
    You will sacrifice the lighting comfort for energy efficiency, the intense glare source (due to high luminances) of every LED lights is terrible. unless, you have a very good
    lenses and this lenses are expensive
    at the moment. You will notice it after prolong exposure or usage of the LED light.
    Aug 2004
    #253
    Mali kasi lighting namin sa bahay. Our room only has one socket in the middle tapos naka recessed housing pa. We need all the intensity we can get especially when the kids are studying. Most of the time naman if we don't need it bright we turn off everything and use the corner lamp which is enough to avoid stepping on evil Lego pieces.
    Aug 2009
    #254
    supporting documents link below
    enjoy reading.
    http://www.etaplighting.com/uploaded...g/Flare_EN.pdf
    Aug 2004
    #255
    Got two 9W and two 5.5W GES from Ace Aura. The sales reps were insisting I get Omni saying it had better output and a wider throw. I was not happy with the Omni CFLs I bought before so I stuck with GES.
    Shadows are sharper compared to CFL but I can now read without straining my eyes. It also looks bluer than CFL white but I can live with it.
    #256
    lubog na socket is wasting light. photogenic, but utterly energy-wasting.
    i remedy this by getting two socket extensions/adapters, put them in series, and install a circular fluorescent tube. voila! it looks pangit, but it brightens the room and reduces shadows.
    Aug 2008
    #257
    Just bought cdr king 7w led. Parang magkasinliwanag lang ang ges 4w on the same room. The ges was first installed and i decided to replace it with a higher one because nahinaan ako and bought cdr king. To my dismay, it seemed that it has the same brightness or light output as the ges.
    #258
    Quote Originally Posted by rac98 View Post
    in my opinion useless to buy cdrking LED bulbs. kasi ang ikli sobra ng warranty and unsure quality. much better buy big brands nalang.
    Wala naman yun e14 type na firefly LED.
    #retzing
    #260
    shadow, have you tried GES? mas maraming options yung GES sa bulb base.
    edit: sa GES meron. 305 yata SRP nung 3w w/ 5 year warranty model na e14. I have the complete price list. di ko lang alam pano i-post dito.
LED light bulbs vs flourescent light bulbs - electric consumption
