Results 1 to 10 of 12
September 19th, 2007 10:31 AM #1
Given the prices of bigger sized LCD TVs are still at P100K level and over, I was thinking of using a LCD projector as a good alternative since prices are between P40K to P65K for a unit and lumens are between 2000 and 2500 lumens. Resolution varies between 640i to 1080i, depending on brand and model. Bulb life is rated at 5000 hours which is good for more than 4 years if you use the projector 3 hours per day, 7 days a week.
One major concern is the bulb replacement. One store quoted me P20K for a replacement bulb and each brand has their particular bulb type.
Second major concern is the quality of the "view". Example, if I have a 1080i LCD projector, will it be clearer than a standard TV and as bright? Assume the room is darkened to optimize viewing quality of the LCD projector.
BTW, video source will be my VHS-PC via VGA port.
Anyone who can answer? Or better yet, someone with experience?Last edited by ghosthunter; September 19th, 2007 at 10:36 AM.
September 19th, 2007 11:06 AM #2
If I were you,- I'd get the LCD TV. IMO, there should be no question on this.
The quality of the picture in the multimedia projector is far off compared with that of the LCD TV (and you need a good 'wall' to project it).
And you're absolutely correct that the cost of the bulb is staggering...
From our experience in the office,- burn-out is quite frequent, so maintenance-wise,- it will turn out to be a more expensive option.
Also, a simple mistake in the power-up /power-down sequence may mean (a costly) outright P20K for you....
3808:fish:
September 19th, 2007 11:25 AM #3
A 2000-2500 lumens projector still won't cut it out... if you want a projector then go for something between 3000-4000 lumens.
But still... it still can't match the clarity of LCD TVs.
September 19th, 2007 12:22 PM #4
The burn-out is due to leaving it on one screen too long. For office or school use, you have the projector on for hours, often showing a static image that burns in.
For occassional home-movie viewing, it should be okay.
But the quality of projectors at the 40-60k range is kinda so-so compared to a good LCD (Philips FTW!), and you'll still need a good sound system and player to back it up (an added 20-40k cost).
Bulbs can go as low as 11-12k, depending on the supplier.
Personally? Just bought a 29" CRT. 20k. I'm just waiting for the extra moolah to afford the new Philips units...
BANNED BANNED BANNED
- 3,790
September 19th, 2007 12:55 PM #5tama si M2 to point out the 3000 lumens and up. This would allow good viewing even if maliwanag ang paligid.
anything below that 3000 lumes is good if you darken your surroundings.
another trick is to get the overhead projector "silver" screen. the screen is somewhat colored silver. this type of screen gives better light reflection. plus you can mount it on your wall or roll it up withou eating so much space.
pede ka ring maglower lumens pero kailangan mag-rear projection set-up ka.
a panasonic and samsung brand seems to have the best value for money lcd projectors... ang have the cheapest cost of replacement bulbs (less than P20k).
kung DIYer ka naman you can DIY an LCD projector with less than P40,000 budget. Good part of this is that the replacement bulb is less than P2000 lang most of the time. DIY lcd projector involves the concept (and parts) of an overhead projector and a strip down lcd monitor. DIY source - http://z6.invisionfree.com/diyprojec...ex.php?act=idx (you might need to register to view the topics).
September 19th, 2007 02:11 PM #7
I was thinking of using a roll up screen mounted on the wall. Right now I know I can get white... I have to check if I can get silvered.
I just checked Virra Mall and there is a shop selling a plasma 40 inch TV made by Panasonic for P70K.Last edited by ghosthunter; September 19th, 2007 at 02:20 PM.
September 19th, 2007 03:49 PM #8
meron ako Epson 2000 lumens nasa bahay. dati gamit ko sa business kaya lang di ko naasikaso.
just size it at 32" like the 32" lcd tv. ok na sya. puwede nasa computer games and yun mga donwloadables 700MB divx movies and series.
i also have epson 1500 lumens malaki ang dipirensya sa quality. the 2000 lumens can operate even when the light is on.
September 19th, 2007 04:11 PM #9
Bro GH, check the "In Focus" brand of projectors. Some of their models are made for home video viewing.
high idle RPM at engine start
