hi.. my ipod seems to be starting by itself or turning itself on even if i did set the keylock on... anyone know why? whats the prognosis...![]()
backup all your songs and format your ipod. pag ayaw pa din, i suggest pa check na sa apple store kung under warranty pa
di po ako siritunes po ginagamit ko, i didnt know may ibang program pala for ipod
... ah..sige i-rereformat ko nalang ito..ang hirap iback-up..pwede ba yan? kasi hindi naka auto-sync with itunes and ipod ko.. maybe.. anyway will give it a try
thanks
Xaxxy, before reformatting your 'Pod, try to check first if you have the alarm on. At some point, you might have gone into the clock of your Ipod and accientally turned on the alarm. Even if you have your keylock activated, or even if the iPod is shut down, once the alarm clock is on, the iPod would play by itself.
Hope this helps.
yes madaming software pa , for ipod, me im using xplay, magaling sya dahil never makikita sa ibang pc yun songs mo. eto pa, kahit san pc mo i-plug ipod mo basta meron syang xplay yun can upload sounds. then after mo upload, icompress ulit nya. para safe. kahit magloko yun ipod ko, ok lang, d nagkakaproblema all my sounds. wag ko lang reset. hehehe!!!
