Results 1 to 20 of 22
    Oct 2003
    Mga bossing, I need help. Medyo bago lang ako sa WLAN and LAN installation. I just recently installed a router para I can use my laptop and pc desktop simultaneously for surfing the net. So far, so good. My problem is I can't connect sa Lan games. I tried using the old Starcraft game and hinahanapan ako IPX. It says I need to put ipx on the other pc. Paano ba maglagay nun? Gusto ko kasi makipaglaro ng games sa mga anak ko, me on the laptop and them sa desktop. Paano ba i-setup lan games using my Linksys WRT54GC?
    Salamat mga repapips!
    Aug 2003
    hindi sa router yan pre. nasa network protocols ng windows mo yan.
    ano ba windows version gamit sa kabilang pc?
    Oct 2003
    Ganun ba pare? Parehong Win XP gamit. Paano baguhin network protocols ng winxp ko?
    Jun 2006
    If i am not mistaken, this has something to do with PORT FORWARDING.
    Please read your Router's manual, it's stated there how to do it.
    I'm not so familiar with the procedure because i haven't tried online games yet.
    Oct 2003
    Contradicting pahayag ninyong dalawa ni Robin at HP. Which is which. So far, wala ako mabasa port forwarding sa Linksys ko kasi web based ko siya na setup.
    Sep 2006
    sa network setting ng pc mo sir binabago....
    magi-install ka ng ipx then ise-set mo ung properties nung ipx...
    meron nang ipx na available sa pc nyo...you just need to install it...
    ung mga settings ng ipx, di ko na matandaan..kung nagla-lan na kayo dati using your desktop, you can just check its setting para gayahin dun sa laptop...
    to check kung meron na dun sa desktop...go to
    start --> setting --> network connection --> local area network
    then
    ung lalabas na screen, click nyo ung property button, meron ulit isa pang screen na lalabas showing the different items available for connection..check kung may ipx item..select it then click the property button...lalabas ung settings nya....
    kung wala pang naka-install
    click install button then protocol, select IPX...press ok...then go back to
    LAN connection property screen.select ung IPX then make the necessary settings...
    ung settings ng IPX, baka meron sa homepage ng mga LAN games...
    hope this works
How To Configure My Router To Play Lan Games
