Originally Posted by
Yoda
Ok, you have to resolve the (possible) firewall issues first. The machines should be able to ping each other and connect to each other's port 139. To test the latter, open a command prompt and enter "telnet 192.168.x.x 139". A successful connection is indicated by the command prompt window blanking out. Otherwise, you'll get an error message like "Connecting To 192.168.x.x...Could not open a connection to host on port 139 : Connect failed".
Pag ok na, you can test file sharing over TCP/IP without removing IPX. Open your network properties, then uncheck IPX on the components list. If it works with IPX disabled, ayos na yan and you can go ahead and remove IPX from the list entirely.
